Simple tube circuit transforming push-pull output transformer into single ended one
Old 7th August 2019, 11:07 AM   #21
disco is offline disco  Netherlands
disco's Avatar
Looks like an elegant solution to me.
jaap
Old 7th August 2019, 11:24 AM   #22
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
No, it isn't elegant at all. The small impedance of the 90 V battery shunts the OT's primary. As KeesB says, a high impedance CCS is mandatory.
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 7th August 2019, 11:34 AM   #23
Lampie519 is offline Lampie519  Netherlands
Lampie519's Avatar
A pentode is just a better current source, that's all. And because you have everything already available to test it as well .... unless you are totally satisfied of course. Do you have a picture of this amp? How much power do you get from it?
Old 7th August 2019, 12:07 PM   #24
kodabmx is offline kodabmx  Canada
Spreading triode love.
Maybe I'm missing something... What's the advantage over using a resistor? Ignore the header...
Old 7th August 2019, 12:11 PM   #25
Lampie519's Avatar
A tube is made to get hot, not so a resistor ;-)
Old 7th August 2019, 12:21 PM   #26
An ordinary resistor comsumes some part of the AF output power.
Best regards!
Old 7th August 2019, 12:48 PM   #27
Horseschitt. That's how they work. They turn power into heat!
True though that a resistor would consume some of the audio, but what about a CCS made from an LM317 and a MOSFET? Or just a pentode with a grounded grid? Then you could drive said grid to have a SE/PP switchable amp?
Old 7th August 2019, 01:10 PM   #28
Lampie519's Avatar
True, a resistor does transform power into heat ! Just this amount of heat we are talking here is not what we want to "burn" in a resistor that's all.
I used a heater wire instead of a resistor to do just that in my single ended amp.
Old 7th August 2019, 01:21 PM   #29
Could use these LOL: Click the image to open in full size.
Old 7th August 2019, 01:35 PM   #30
Lampie519's Avatar
Haha... nice in the winter.... the audiophile's heater.
Simple tube circuit transforming push-pull output transformer into single ended oneHide this!Advertise here!
45/2a3 single ended tube amplifier circuit for 45 tubes only use adjustments kkstereo Tubes / Valves 30 18th May 2019 02:44 AM
Single Ended Output Transformer mensur Tubes / Valves 1 24th August 2016 02:50 AM
Single ended transformer as pushpull? jim Tubes / Valves 22 10th July 2014 05:54 PM
for ultimate fidelity pushpull or single ended? rhythmsandy Solid State 5 24th September 2012 09:43 PM
Output Transformer; Push Pull to Single Ended? searon386 Parts 3 10th August 2011 10:41 PM
Copyright ©1999-2019 diyAudio
