Local feedback between grid-cathode
Old 28th July 2019, 09:38 AM   #81
JoeAlders is offline JoeAlders  Netherlands
Originally Posted by Wavebourn View Post
Why you stuck on UL? What's the point?
Reading all those responses I fully agree with Wavebourn's
question!
Old 28th July 2019, 11:58 AM   #82
gabdx is online now gabdx  Canada
I never built a pentode amp, this is my first. (well I built 2 CCS with pentodes with great success first try, just a few adjustments, pentodes are very easy to work with)
Looking at the pentode curves I assume that the gain mu is higher than in UL
As consequence I could run the amp with GNF(decent amount) + CBF, without overtaxing the poor little 6sn7 LTP.
At worst, I will disconnect the G2 supply which I aim to be around 400V, I never push the amp past 30 watts, and I will keep there the regulated supply for gain and splitter LTP.
I am just afraid that Pentode mode with GNF and CBF wont beat GNF + UL, audibly and in measurements. The bar is very high...
amplificateurslegrand.ca
Old 28th July 2019, 05:11 PM   #83
45 is offline 45  Italy
45's Avatar
So in the end it is basically a design flaw where the driver is not up to the task. Learning curve...no problem.
When using CFB this has to be taken into account before building anything. Usually CFB windings are in 5-10% ratio so it is not even remotely close to high demand of a cathode follower but it needs careful design nonetheless especially when the sensitivity and/or power level of the output tubes requires significant swing (without CFB already).
Old 28th July 2019, 05:19 PM   #84
45, I am just switching transformers in an old design to test all possibilities. I never intended this amplifier to have a CFB. I purchased the transformers last year for a new project, the mono blocks were built by me 15 years ago.
If there is something that I am learning here it is first, the pentode outputs, which I will see in a few days when I have my G2 fuse, second, that the output transformer quality counts a lot more than I thought.
It was overconfident in UL and GNF to resolve all audible flaws of output transformers. I though a hifi level transformer of good power was sufficient if non-linearities were addressed by global/local, UL, feedbacks. I knew that in SET the quality was paramount, I just didn't thought it would make such a big difference in a push-pull design.
I know that good designs do not use UL, for some reasons, it is always pentode with regulated G2 and regulated G1 bias.
I doubt that it is that good, I will see for myself in a few days, and I have big doubts because I find the sound in UL hard to improve upon, it is quite superb actually.
I am doing this in the perspective of the ultimate amplifier....
A direct zirconium contact input to a 6sn7 frosted, with a high pressure big carbon track mono volume pot, followed with a ecc99 with el822 LTP at around 15ma with over 450V of potential, to the kt120 in UL ( or pentode with CFB) to quads modified exotic super core transformers of around 150 watts, (they already blasted in THD and clearly audible differences my other OTs from 25 to over 100Watts).
The mono block will use a full wave, super high power soft diodes, with film input capacitor, then a 10H 200ma choke, and a 280uf 1000V capacitor to the HV B+.
The bias is regulated from a dedicated transformer with the uttermost quality trim-pots.
The pre sections are all film caps, super high power, regulated 100%. The anode resistors are super huge like 2 inches long, non-inductive super resistors, crazy
Old 4th August 2019, 02:48 PM   #85
kodabmx is offline kodabmx  Canada
Spreading triode love.
gabdx: Have you considered using one of these for a cheap and cheerful screen supply?
DC-DC 8-32V to +-45V-390V Step-up Module ZVS High Voltage Capacitor Charge Board | eBay
I have several, if you like I can send you one for 5$ plus postage. Probably the same price as ordering from China, but you'll get it in days, not weeks.
Old 6th August 2019, 12:00 AM   #86
Hi Kodabmx, I appreciate your offer.
I decline, I build my own regulator
Old 19th August 2019, 07:31 PM   #87
jhstewart9 is offline jhstewart9  Canada
jhstewart9's Avatar
Norman Crowhurst covers all the popular NFB schemes used in the Power stage. This is a very good read.
The comparative qualities of the various ccts is given on p8.
Old 20th August 2019, 01:40 AM   #88
I would agree on this, I find the UL with proper Z matching is heaven on earth with a quality OT...
It seems that pentode is not the end of the world, contrary to the forum general consensus. However I will try it pretty soon !
Just need to make sure I have all the parts before I place the order to build 2 new monoblocks.
One thing will be different is that I will use 4 power transformer this time. One for power tube bias, 2n for power tube B+ CLC and heaters, 3rd for pentode current sink (-135V supply) and its heaters. 4th is going to supply the new regulated supply to the input tube and LTP ecc99 as well as if required to the control grid in pentode mode.
Old 20th August 2019, 03:07 AM   #89
SpreadSpectrum is online now SpreadSpectrum  United States
SpreadSpectrum's Avatar
I don't see anything in Crowhurst's article that shows that Ultralinear is superior to pentode with voltage feedback to the control grid. What did you see in there that contradicts this?
My Blog: http://tubeswithatwist.blogspot.com/
Old 20th August 2019, 08:00 PM   #90
Wavebourn is offline Wavebourn  United States
Anatoliy Lisovskiy
Wavebourn's Avatar
...and I saw no other than UL feedbacks there. Just an attempt to prove that pentode mode for Cyrclortron is the best.
!!!Warning!!!
Single Ended Class-A-Holism is addictive!!!
Local feedback between grid-cathodeHide this!Advertise here!
LTP feedback return. Cathode or grid? Elerion Tubes / Valves 8 15th May 2019 11:31 AM
Control Grid Feedback (as opposed to Cathode FB) and Miller Capacitance ballpencil Tubes / Valves 10 18th November 2015 12:07 AM
Partial feedback (anode grid) with cathode follower swordsman Tubes / Valves 6 9th July 2011 06:29 AM
Neg-Feedback into Grid of gain stage instead of cathode? Alastair E Tubes / Valves 3 25th January 2011 10:19 AM
300B SE cathode feedback to grid? alan_982002 Tubes / Valves 3 29th March 2010 01:04 PM
Copyright ©1999-2019 diyAudio
