Local feedback between grid-cathode
Old 20th August 2019, 08:24 PM   #91
SpreadSpectrum is offline SpreadSpectrum  United States
SpreadSpectrum's Avatar
Well, the tetrode cathode follower, Unity-Coupled, and Circlotron are all pentodes with voltage feedback to the grid. They perform much better than UL but it really isn't a fair comparison to UL since there is so much feedback (50% - 100%). A fair comparison would be to construct a circuit with just enough plate-grid feedback to give the same amount of gain as the UL circuit.
I have no doubt that this would give less distortion than UL because you are applying the error correction to the electrode that gave rise to the error in the first place, not some other electrode with other characteristics.
My Blog: http://tubeswithatwist.blogspot.com/
Old 20th August 2019, 09:31 PM   #92
Wavebourn is offline Wavebourn  United States
Anatoliy Lisovskiy
Wavebourn's Avatar
Exactly. The name "Ultra Linear" is misleading and is responsible for it's undeserved popularity.
!!!Warning!!!
Single Ended Class-A-Holism is addictive!!!
Old 21st August 2019, 12:10 PM   #93
Ketje is offline Ketje  Belgium
Ketje's Avatar
Here are the dynamic Ia-Vg1 curves for the 3 choises with the KT88.
One can see that the UL is the more linear.To call it ultra is to much honor
Mona
Old 21st August 2019, 02:50 PM   #94
jhstewart9 is offline jhstewart9  Canada
jhstewart9's Avatar
Default Amplifiers & Superlatives
Langford Smiths Paper UL vs CFB, a good read.
Old 21st August 2019, 02:51 PM   #95
jazbo8 is offline jazbo8
jazbo8's Avatar
I think you meant Williamson & Walker...
Old 21st August 2019, 03:56 PM   #96
smoking-amp is offline smoking-amp  United States
smoking-amp's Avatar
Here are some Vg1 to Ip curve traces for 26LX6 (50 mA per div Vert.)
a) grid 1 drive
b) Crazy drive (grid1 and grid2 special combo) (5.4 V steps)
c) 26LX6 low current end in Crazy Drive (10 mA per div Vert.) (showing low end for class aB overlap)
d) 36LW6 normal plate curves in Crazy drive (50 mA/div) (5 V steps)
e) 36LW6 plate curves for grid 1 drive
f) 26LX6 plate curves for grid 1 drive
g) 26LX6 plate curves for Crazy drive
Ultra linear, hmmm
Old 21st August 2019, 04:14 PM   #97
I just want to point out that in QUAD output stage in the Williamson and Walker paper, the cathode feedback stage also has negative feedback to the screen. So that paper is really comparing UL with UL+CFB. Neither of the output stages examined are Pentode/Tetrode+CFB. If you want to combine Pentode and CFB you have to keep the voltage between screen and cathode constant which requires extra effort in floating supplies or extra OT windings or special cases (like Unity-Coupled config).
Old 21st August 2019, 11:01 PM   #98
gabdx is offline gabdx  Canada
To me UL is way superior to UL+CFB,
A great amount of UL is enough and GNF works a lot better to reduce any amplifier parts coloration, reducing GNF and using then CFB corrects only the output stage.
GNF reduces the output Z enough, with UL, so that the CFB is useless and there is no benefits from reducing the output Z more.
To me, with thd levels inaudible, UL was the clear winner over UL + CFB.
However I am curious about pentode + CFB, which will enable same gain levels with a decent amount of GNF.
In other words, the pentode higher gain, plus the CFB plus around same level of GNF is the highest gain, highest feedback solution.
Logically the higher gain, higher feedback levels should sound better, we will see.
Table 1 in the article refers to stability. this is where pentode is weak.
I am thinking about running the KT120 with a G2 at higher voltage than the anode... regulated.
amplificateurslegrand.ca
Local feedback between grid-cathodeHide this!Advertise here!
LTP feedback return. Cathode or grid? Elerion Tubes / Valves 8 15th May 2019 11:31 AM
Control Grid Feedback (as opposed to Cathode FB) and Miller Capacitance ballpencil Tubes / Valves 10 18th November 2015 12:07 AM
Partial feedback (anode grid) with cathode follower swordsman Tubes / Valves 6 9th July 2011 06:29 AM
Neg-Feedback into Grid of gain stage instead of cathode? Alastair E Tubes / Valves 3 25th January 2011 10:19 AM
300B SE cathode feedback to grid? alan_982002 Tubes / Valves 3 29th March 2010 01:04 PM
Copyright ©1999-2019 diyAudio
