DC coupled single ended cathode follower 6SJ7/6V6 amp project
Old 18th July 2019, 02:50 AM   #11
Bigun is offline Bigun  Canada
Bigun's Avatar
in common cathode gain stage the 10k resistor you refer to is the load against which the tube works to generate voltage gain. for the output of a power amplifier the output transformer is the load and the voltage developed across it (current) will couple into the load through the secondary winding. A resistor in series with the output transformer will simply waste heat and contribute nothing to the load. But being direct coupled you need to lift the output tube off ground and so you end up needing this resistor.
There is some stabilization of the operating point going on as the cathode of the 6V6 is connected to the screen of the input tube and this feedback to the screen of the input will help linearize it and improve the PSRR.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 18th July 2019, 03:10 AM   #12
PRR is offline PRR  United States
PRR's Avatar
Originally Posted by 45 View Post
Not the first time this amp is mentioned. I doubt one can get the claimed 4.5W with that circuit. . .
My sim with similar tubes gives 5.5%THD at 10Vrms across 6K load: 0.016 Watts. 22%THD at 42Vrms in 6k; 0.3W output.
Old 18th July 2019, 03:11 AM   #13
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
In this case the resistor is not bypassed, so a good chunk of the AC output voltage winds up being burnt up in this resistor too, so it steals power from the load.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 18th July 2019, 03:22 AM   #14
Bigun's Avatar
did anybody attempt checking that the schematic matches the wiring in the photo - a thankless task given the poor quality of the photo of course.
Old 18th July 2019, 03:54 AM   #15
PRR's Avatar
....If the 6SJ7 and the 6V6 are RC coupled then you have complete freedom about quiescent conditions of the input tube and can be adjusted to what one needs.
AC-coupled, you can do a heap better. Easily 10X the power. Still seriously distorted at any useful power.
My gut says it is not worth tracing the schematic against the chassis photo. A 6V6 as Triode just CAN'T make 4 real Watts SE. (Couple watts at best.) Bates clearly did not METER TEST this amp, just "assumed" it would reach normal-operation output.
Old 18th July 2019, 10:36 AM   #16
45 is offline 45  Italy
45's Avatar
Yes. With a cathode follower output one just moves the troubles to the input stage and actually it's even bigger trouble. Not so many solutions to get 180V RMS swing with little distortions. If it also has to be cheap even worse..... One needs a good device with its own power supply. That's why that circuit has remained unnoticed and no one addressed those design mistakes.
Old 18th July 2019, 10:39 AM   #17
DF96 is offline DF96  England
It is obvious that the original author did not understand his own circuit. If he understood it he would have quietly buried it and felt embarrassed, not published it for everyone to see. Maybe he was drunk when he designed it?
He may have built it and listened to it. A 100mW can sound fine with a high efficiency speaker. I guess he didn't have an oscilloscope.
Old 18th July 2019, 11:58 AM   #18
Dinolobe is offline Dinolobe  Canada
I think i’ve had my answer now. The other threads i’ve read about the circuit weren’t as detailed as to why the circuit won’t work or give satisfactory results. They sounded more like haters anything else. Now it’s getting clearer that i’ll be loosing my time building it even though it could be converted into something else easily. Too bad ! I really liked the idea behind it, but too good to be true.
Any ideas for a useful amp that would make good use those parts ? It could be with different valves too. Something like a Single ended el84, el34, 6v6...
Old 18th July 2019, 12:00 PM   #19
Sodacose is offline Sodacose  United States
Sodacose's Avatar
With the pentode input, it is begging for some "schade" style plate to grid feedback.
Old 18th July 2019, 12:56 PM   #20
You could make a simple SE. It won't be hi-fi, but it could make pleasant noises.
DC coupled single ended cathode follower 6SJ7/6V6 amp projectHide this!Advertise here!
Transformer coupled cathode follower power? Sodacose Tubes / Valves 28 29th December 2016 05:55 PM
DC Coupled Cathode Follower Questions steeledriver Instruments and Amps 22 1st April 2016 04:57 PM
A case of direct coupled cathode follower Mosquito Tubes / Valves 62 9th June 2014 03:06 PM
DC coupled cathode follower driving me nuts funk1980 Tubes / Valves 12 9th November 2011 06:48 PM
A Direct-Coupled Amplifier with Cathode Follower 6V6 livingdeliberately Tubes / Valves 6 31st March 2011 07:41 PM
Copyright ©1999-2019 diyAudio
