DC coupled single ended cathode follower 6SJ7/6V6 amp project
Old 27th July 2019, 06:07 PM   #91
Dinolobe is offline Dinolobe  Canada
I measured my output transformers and adjusted the values accordingly into the simulation. The result is a half square half sine wave with unequal spikes everywhere. Do I get those results because the circuit doesn’t fit the OPTs or because I have to enter appropriate values in order for the simulation to work properly ? Here are the measurements :
Primary : 225 dcr / 5k ohm / 2.26Hy
Secondary : 0.01 dcr / 8 ohm
Inductance measured with cheap LCR meter, I am not shure if I can trust the results, especially when considering that the simulation has a 1khz input signal and the tester probably only does DC...
Old 27th July 2019, 09:01 PM   #92
piano3 is offline piano3  United Kingdom
You can't measure iron cored inductors with a multi-meter; you need to apply known AC voltages at known frequencies, measure the currents and calculate inductance using the formula for inductive impedance.
Old 28th July 2019, 12:54 PM   #93
rongon is offline rongon  United States
rongon's Avatar
You should be able to get a decent simulation using a pre-existing model of an OPT that's similar to the one you'll be using.
A few years ago, someone contributed an Excel spreadsheet with a good number of useful OPT models, which I've been using for simulations. (Whoever you are -- Thank you!) It won't get you an *exact* sim of your circuit, but it will allow you to get close. Once you have a simulation that looks good to you, build it and do the necessary tweaking.
I've attached the Transformer Models Rev4.xls file in a zip. I hope it proves useful.
PS - There's a discussion of OPT models for LTspice on the Intact Audio site:
:: View topic - Drop down transformer models for LTSpice
Old 28th July 2019, 05:35 PM   #94
jhstewart9 is offline jhstewart9  Canada
jhstewart9's Avatar
Default Summary of Triode Output Stage
This article should help. All summed up well in the last two paragraphs.
DC coupled single ended cathode follower 6SJ7/6V6 amp projectHide this!Advertise here!
Transformer coupled cathode follower power? Sodacose Tubes / Valves 28 29th December 2016 04:55 PM
DC Coupled Cathode Follower Questions steeledriver Instruments and Amps 22 1st April 2016 03:57 PM
A case of direct coupled cathode follower Mosquito Tubes / Valves 62 9th June 2014 02:06 PM
DC coupled cathode follower driving me nuts funk1980 Tubes / Valves 12 9th November 2011 05:48 PM
A Direct-Coupled Amplifier with Cathode Follower 6V6 livingdeliberately Tubes / Valves 6 31st March 2011 06:41 PM
Copyright ©1999-2019 diyAudio
