Stupid question regarding chokes
Old 24th July 2019, 08:46 AM   #21
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
OK, yes I agree. But I thought that saying the extra IM is caused by the collapsing choke inductance is a bit far fetched. I could well imagine an amplifier with high PSRR that is pretty immune to it.
You might as well say that the collapsing inductance increases output power because it will make the average supply voltage to increase.
About the only thing you can say for sure is that the ripple on the supply lines will increase, which is a direct consequence of the lower inductance.
But yes, your reasoning is OK in principle ;-)
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 24th July 2019, 12:14 PM   #22
Smoky Black is offline Smoky Black  United States
I did some more experimenting. The power tube bypass cap had a slight effect. I tried a few different values, but ended up with 220. I may still go back to the 470, because I think it may have sounded better.
The problem was still there. As an experiment, I hooked up my variac and determined that if I lowered the voltage, roughly 100 volts ac, the problem went away. The bias of the power tubes dropped to around 72 ma, which with the 6sn7, puts it right around the 80 ma of the choke. Then I had to see whether it was the lower voltage or the choke, which prompted me to disconnect one end of the choke and try a 470 ohm resistor.
With the resistor, the problem went away. It was still a bit lower voltage and it didn’t sound as good. There was some slight hum at the speaker. As a final experiment, I clipped the choke in parallel with the resistor. In that configuration, the voltages were just about back to where I wanted them, and the sound seemed almost as good as it was. I can’t help but suspect that slight difference was the different cathode bypass capacitor.
So, it was the choke after all and I believe it was acting as Disco suspected - IMD at loud passages. Thanks so much for the assistance. I’m going to have to buy a better choke, now!
Old 24th July 2019, 12:38 PM   #23
disco is offline disco  Netherlands
disco's Avatar
Take a look at this useful software: PSUD2 It has a modest learning curve and gives you insight in what's going on in the power supply.
Look for a choke that does allow for 150mA and has low copper resistance. You always can add an extra RC filter up front, if necessary.
jaap
Old 25th July 2019, 03:00 AM   #24
I bought a Hammond 193G, 10H, 150ma, 102 ohms. Then, the plan will is to work a resistor between the diodes and first filter cap to set the voltage.
Somewhat off topic, but while I’ve got the attention of some very knowledgeable folks, what are everyone’s thoughts on the two channels’ EL84s sharing a bias resistor? Is that it better to give each tube its own cathode bias resistor and bypass cap?
Old 26th July 2019, 01:40 AM   #25
DAK808 is offline DAK808  United States
Is this a 2 channel amp? I always use a single a bias resistor for each power tube. It is not really necessary, but, in my SE amps i like it that each power tube has its own resistor and bias cap. You need to double the value of the resistor. Bypass cap should be more than 50uf for an el84 but some guys like 100uf.
Old 26th July 2019, 07:09 AM   #26
disco's Avatar
Originally Posted by Smoky Black View Post
what ... two channels’ EL84s sharing a bias resistor? Is it better to give each tube its own cathode bias resistor and bypass cap?
The EL84s are in opposite phase, only in theory equally. Connecting both cathodes brings them at the same DC level (which still wanders around in time) what helps for exact and opposite phase reproduction.
jaap
Old 26th July 2019, 08:04 AM   #27
disco's Avatar
In this example a CCS actively regulates the cathode current for the compound of both EL84s. (Forget the pot, it's there to compensate for an unbalanced pair of EL84s.) Arguements in favour of applying this constant current source is to obtain maximal undistorted output power and having unequalled low frequency output. Against is loss of agreeable tone, to which one could listen without getting tired.
jaap
Old 26th July 2019, 08:47 AM   #28
disco's Avatar
But, in single ended application, this is all unnecessary. You should not connect the cathodes of your left and right channel output valve. You could experiment with the above CCS and see what it brings. Respect the maximal plate dissipation though.
jaap
Stupid question regarding chokesHide this!Advertise here!
Maybe stupid question WrineX Planars & Exotics 9 9th January 2013 09:52 AM
such a stupid question (probably) fusion Chip Amps 2 25th January 2008 04:35 PM
Stupid question Leolabs Everything Else 2 8th July 2006 02:09 AM
Stupid question red Solid State 8 23rd May 2004 09:03 PM
Copyright ©1999-2019 diyAudio
