I'm not familiar with Lundahl outputs. I have used their PP outputs once, but it called for a straight forward UL tap. I am working on this amp:
https://www.lundahltransformers.com/wp-content/uploads/datasheets/cb-amplifier_8wse.pdf
It calls for 50% UL tap. I have the 100mA output versus the 80mA output, but minus inductance it should work all the same. Is the image below I have modified the correct way to wire for 50% UL tap? I modified the data sheet, to include any additional information even though it looks like a factory data sheet, it is modified.
Thanks!
Thanks!
