What tubes are used?
Old 11th July 2019, 01:35 AM   #51
Junm is offline Junm  Philippines
Junm's Avatar
Send a message via Yahoo to Junm
Does anybody know the specs of the Input Transformer? it Lux 3657P. i've search google and i was able to find images only and the 3656P . If Driven by 37 or 56 triodes on this amp so it might have more than 5 ma of primary current? how about secondary and most especially the turns ratio?
I might burn the IT if feed with excessive current?
Old 11th July 2019, 02:53 AM   #52
jazbo8 is offline jazbo8
jazbo8's Avatar
Itís a 1:3 step up IT, likely with an air-gap, so no need to worry about the DC current (within reason of course).
Old 12th July 2019, 01:16 AM   #53
Junm's Avatar
Thanks again Jazbo.
Now its clearer for me to do the projects with option as per owner request. He wants to maximize the OPT around 8-10w max with PP triode but the Power trafo will not be sufficient at 0nly 80ma capability. pentode and tetrode will do but on Triode its I think not doable. Any Idea?
Old 12th July 2019, 01:20 AM   #54
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
just do it first with what is available, output wattage with tubes is nothing to lose sleep about....then listen to it and judge for yourself if you like what you heard..
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 15th July 2019, 05:14 AM   #55
Junm's Avatar
Yes Sir tony...i will let her listen to the final build first then make adjustment if she's not satisfied with it..
What tubes are used?Hide this!Advertise here!
FS: 76 Tubes and pair of Herbies Tube Dampers for 76 tubes carlsor Swap Meet 2 3rd January 2019 03:45 AM
Parts Connexion's 25% off New Tubes, NOS Tubes & Sockets Sale !! PCXstaff Parts Connexion 4 18th February 2016 09:50 PM
Parts Connexion's 25% off New Tubes, NOS Tubes & Sockets Sale !! PCXstaff Vendor's Bazaar 0 9th February 2016 09:58 PM
Runaway tubes or tubes drawing excess current--baffling trombone Tubes / Valves 13 16th April 2011 11:27 AM
Copyright ©1999-2019 diyAudio
