Need advice on OPT impedance
Old 14th June 2019, 02:27 PM   #1
ggetzoff is offline ggetzoff  United States
ggetzoff's Avatar
Default Need advice on OPT impedance
I'm going to build my first tube amp and my loudspeaker is a 4 ohm stati design.
My thinking is that I should custom order OPTs with 4 ohm secondaries. I do have an option, Transcendar (they are back in business), could do dual 4-8 ohm secondaries and I could then switch to to see which secondaries sounds better. But, that will be more $$.
Any thoughts?
Airline Pilot-If it's not Boeing I'm not going.
Aleph J, DCB1, VHEX + USSA-5, BA-3 Pre, DCG3, USSPA, Transcendent Sound Masterpiece
Old 14th June 2019, 02:43 PM   #2
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
There are TONS of ready built 4 ohm output transformers, why custom build?
Plus we need more information about what you want to build.
Schematic, etc.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 14th June 2019, 02:59 PM   #3
ggetzoff's Avatar
Schematic, etc.
Sorry, building the Get*Set*Go
getsetgo_manual.pdf
Yes, there are tons of OPTs, but every product I am considering are made to order anyway, even big brands like Edcor are made to order. So I can choose
Old 14th June 2019, 06:34 PM   #4
huggygood is offline huggygood  France
just a tip,do you make or buy opt with secondary 4 and 8 ohm, it will allow you later to play with your diagram and/or your power tubes .
Old 19th June 2019, 11:30 AM   #5
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Side question: Why do you use an image of Bob Ross as avatar? Are you him?
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 19th June 2019, 11:34 AM   #6
schiirrn is online now schiirrn  Germany
Bob Ross died 1995.
Preferred BSC? Just using a wide enough baffle.
Old 19th June 2019, 11:55 AM   #7
Oops, didn't know that !
Best regards!
Need advice on OPT impedanceHide this!Advertise here!
Twin Peaks - Impedance measurement advice needed! kr1s Full Range 28 10th March 2015 12:27 AM
need advice regarding impedance issue kevinr Full Range 42 26th November 2013 03:27 PM
Advice sought on impedance choice for DIY sub on a TDA2030A BTL amp Eschatonic Subwoofers 2 28th November 2012 03:30 AM
Need help understanding transformer impedance ratios and impedance matching percy Tubes / Valves 5 28th February 2005 08:35 PM
x-o impedance advice please. Andy G Multi-Way 3 11th December 2002 04:07 PM
Copyright ©1999-2019 diyAudio
