Noise Problem, Help Please
Old 11th June 2019, 09:49 PM   #31
Troy Madden is offline Troy Madden  United States
I'm going to try regulated DC for the entire front end of the amp. Just happened to have a little power supply board laying around. Even has provision for elevating the filaments.
Down to 6.5 mV noise with regulated supply!
Old 11th June 2019, 10:27 PM   #32
as_audio is offline as_audio
Was filament noise ?
After that it should be possible to go down to 1 mV or less.
Old 11th June 2019, 11:17 PM   #33
Yes, the majority of the noise was induced by the filament supply. I just connected a separate filament transformer. That didn't bring the noise down any further, but if I hold a grounded copper sheet near the bottom side of the amp, I can get noise down to 4.5 mV. So I may line the wooden case I made with copper sheet.
Old 12th June 2019, 01:23 PM   #34
Thanks, everyone for your help!
Noise Problem, Help PleaseHide this!Advertise here!
Noise problem coolhead Power Supplies 6 5th March 2012 03:22 AM
noise problem vidc Chip Amps 2 5th January 2010 05:51 PM
Noise Problem. raveenvijendren Solid State 0 14th November 2005 06:03 AM
Noise Problem Jackson Yaya Solid State 4 6th June 2005 06:08 PM
noise problem danyel Chip Amps 3 23rd February 2005 10:59 AM
Copyright ©1999-2019 diyAudio
