5U4G power supply to 274B
5U4G power supply to 274B Please consider donating to help us continue to serve you.
Old 25th May 2019, 01:02 AM   #21
Peckjed is offline Peckjed
Originally Posted by grovergardner View Post
Um, I wouldn't put a switch at full B+. Just use 10uF, the 5U4's will last longer that way.
Sounds like a 10uF would probably work with a 274B and 5U4. I may be being sent some Mundorf 3.9uF for free, it seems like these would work well for the 274B... would it also work for the 5U4?
Old 25th May 2019, 02:45 AM   #22
grovergardner is offline grovergardner  United States
Sure, if they're rated for 600+ vdc. Check your B+ afterward, though, it may be lower than you want. And you may get an increase in ripple noise.
Old 25th May 2019, 05:56 AM   #23
fred76 is offline fred76  Philippines
Actually, the datasheet specifies 4uF for max duty. This circuit draws about 80mA, about a third of the max for a 274A. In my experience 10uF here is not a problem.
Thanks Grover.. The 5R4G is close in ratings and might be a good substitute too for the PSU I linked. Peckjed’s circuit looks like it could work with the 5R4G(Y) too if input cap is reduced to 10uF..
Old 25th May 2019, 08:20 AM   #24
The 5R4 is a nice tube.
Old 25th May 2019, 09:06 AM   #25
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
what is the dc resistance of the windings feeding the plates of the rectifier? if lower than 100 ohms you can series connect 3 watt resistors to make the dc resistance to about 100 ohms per side, even somewhat more can help....
hard work erases ignorance.....
Old 2nd December 2019, 11:53 PM   #26
I know this was from a while ago. I installed the 10uF cap in place of the 30uF and the diodes on the rectifier. No issues with the rectifier anymore! However, I am noticing a hum from the choke that’s seems to be transferring to a 60hz hum on the speakers. Could lowering the 30uF to 10uF have caused this?
Old 3rd December 2019, 12:05 AM   #27
kodabmx is offline kodabmx  Canada
Spreading triode love.
No. That hum (if any) would be 120Hz. Are you sure it's not 120Hz?
60Hz usually is caused by ground loops/heater hum. If you short the inputs to ground, does the hum go away? If yes, it's a ground loop.
Does the hum go away as soon as you switch the amp off? If yes, this means it's coming from the power supply of the amp, either electrically, or magnetically.
Old 3rd December 2019, 12:14 AM   #28
There is a small amount of 120hz hum, but also lower frequency 60hz. (If my understanding is correct 120hz is higher pitched, almost a buzz and 60hz is lower pitched hum).
I’ll test if the hum goes away when shorting the input.
Yes, the hum goes away as soon as I power the amplifier off.
This is the power simply schematic: Legend power supply - Album on Imgur
Dumb question - can a choke be wired backwards?
Old 3rd December 2019, 01:02 AM   #29
Not usually, no... However I've read that the polarity can make a difference on certain chokes that were designed a certain way...
5U4G power supply to 274BHide this!Advertise here!
FS: TJ Full Music 274B/n Mesh Plate craigtone Swap Meet 1 1st November 2017 09:05 PM
Is my 274b/n defective cowneko Tubes / Valves 98 1st August 2016 06:40 AM
replace 5R4GA to WE 274B audioland Tubes / Valves 2 9th May 2016 03:34 AM
FS: Western Electric 274A & 274B tubes thehoj Swap Meet 1 9th September 2015 03:38 PM
WE JAN 274B Dating tvan56 Tubes / Valves 0 27th July 2012 11:18 PM
Copyright ©1999-2019 diyAudio
