Bypass a tube to reduce power?
Old 20th April 2019, 11:16 AM   #41
huggygood is offline huggygood  France
in fact it is always the same .
someone asks a simple question and it goes in all directions while the most appropriate answers were given at the beginning of the thread.
a divider bridge and / or a triode arrangement of the EL34s.
it can not be easier and more effective to answer the question.
Old 20th April 2019, 01:04 PM   #42
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
That's why I seldom enter a thread when it is longer than a couple of pages. By that time most are already a train wreck ;-)
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 20th April 2019, 01:33 PM   #43
not false
Old 20th April 2019, 10:59 PM   #44
pblix is offline pblix  United States
pblix's Avatar
Originally Posted by jan.didden View Post
This seems a very drastic and non-optimal plan to solve something that can be fixed by a couple of $ 0.10 resistors ...
And, lets call it what it is: you are NOT looking for a lower power amp. If the new amp has the same gain as the old one, it will sound exactly as loud as the old one!!
A 50W amp with 20x gain will sound just as loud on your speakers as a 20W amp with gain 20x. Get that. You want lower gain!!
Jan
I believe I said flea-watt. Typically 1-2W. You don't think that would do it? You'll save trees in the process.
Old 20th April 2019, 11:03 PM   #45
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
It depends on who started, and for what purpose. ;-)
My thread has lot of wisdom added over the years by many contributors!
One more 4P1L SE
!!!Warning!!!
Single Ended Class-A-Holism is addictive!!!
Bypass a tube to reduce power?Hide this!Advertise here!
Power Tube Cathode Bypass Cap Value sony6060 Tubes / Valves 6 8th August 2018 10:09 PM
Decware Zbox - looking for Tube buffer mods to reduce buzz speakerfritz Tubes / Valves 18 18th February 2012 10:06 PM
tube preamp mod for bass bypass to ss power IN? awangotango Analog Line Level 2 7th January 2011 07:07 PM
How to reduce gain of this Tube Preamplifier ? ANALOG GUY Tubes / Valves 5 22nd September 2006 03:37 AM
Does a cathode bypass capacitor reduce hum? ray_moth Tubes / Valves 23 21st August 2004 01:38 AM
Copyright ©1999-2019 diyAudio
