EAR the preamp
EAR the preamp
Old 17th April 2019, 02:54 PM   #11
huggygood is offline huggygood  France
from here, it's an EAR 802, if it helps.
Old 17th April 2019, 04:51 PM   #12
kstagger is offline kstagger  United States
kstagger's Avatar
Tube socket and pot / switch cleaning, followed by some new/used and tested tubes would work wonders.
Those blue axial electrolytics look to be made by Ero and may still be available; I used ERO caps that looked exactly the same bodystyle and color for a McIntosh 250 (SS amp) rebuild. I would also replace the radial caps.
edit: or Roederstein caps. Been a few years.
Old 17th April 2019, 05:03 PM   #13
Philips capacitors
Old 17th April 2019, 06:43 PM   #14
brucetassin is offline brucetassin  United States
Hello Reinhard.
Go to analog source and look up my post "wave Form".
I'm having a hard time with this pre amp.
Old 17th April 2019, 06:46 PM   #15
Never mind, My amp is an EAR834.
Sorry
Old 18th April 2019, 12:42 AM   #16
avtech23 is offline avtech23  Australia
Certifiably addicted to DIY.
avtech23's Avatar
EAR the preamp
The OP's one is the predecessor to the 802. It has 14 tubes versus the 6 in the 802.
+1
Hum can be caused by the breakdown of the power supply electrolytic caps - I'd replace those as a minimum.
The ever growing project list.. :NAP140 Clone, NAD 3020i & 3225PE, JLH1969, TDA2050, Fender 5F2A Princeton, NE5532 Pre, SHPA, B1 Korg. : VSQC Phunk Style, Retro 50W, Filmosound 601. : Apex AX-14, TGM-10, TDA7265, LM4780 (Last in line)...maybe
Old 18th April 2019, 09:04 AM   #17
+1
I will not neglect the increase of the mains voltage either.
I had the case with a CJ recently to have the ECC83 had cathode / heater leaks.
thanks for the info .
I sold some as a professional seller several years ago, but I never opened one, it was still "magic boxes" for me at the time.
EAR the preampHide this!Advertise here!
Viking RP61 tube preamp into Mic preamp? Magnetmaz Instruments and Amps 1 7th April 2015 08:47 PM
Running a tube preamp into a solid state preamp? Pckid212 Solid State 5 6th January 2013 10:12 PM
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps Travis Clarke Tubes / Valves 3 16th October 2008 04:52 AM
twisted pear Preamp/other suggestions for Preamp kit LukeDuke Chip Amps 1 1st February 2008 09:57 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
Copyright ©1999-2019 diyAudio
