Lafayette single ended from the 60's
In the Netherlands imported and distributed as Kontakt. The particular model is NS-12. Output tube 6BM8 / ECL82.
The question I have. Does anyone know what model that was in the Lafayette catalog? And more importantly if the output transformers were made with nickel as magnetic material? The reason I ask is they look like nickel.
Thanks for any info you may have.
Picture of the front included.
  • 687474703a2f2f7777772e66616d696c69652d70726f736d616e2e6e6c2f50524f4a454354532f4e5331325f564f4f52.jpg
A view of the bottom of the transformer would be instructive. What you see on the sides may well be the mounting bracket. Usually the lams can seen directly in a bottom view. I doubt that a lowish-end product like this would bother with nickel-iron laminations.
attachment.php
Got rid of the mounting bracket. I always remove magnetic and conductive mounting brackets. The picture above is of the second one where the bracket has not been removed yet.
I doubt that too. It's just that nickel probably only makes sense in low powered amps. And it sure looks unlike "other" laminates and transformers found in similar amps. So I thought I might have gotten lucky. OTOH it might be that it is extra cheap without the usual electrical "insulation" to reduce eddy currents. The last is most likely ofcourse....since the transformer edges are wrapped in plastic in order not to make contact with the bracket.
