active v.s. passive phono
Old 18th April 2019, 05:40 AM   #31
soulmerchant is offline soulmerchant  Switzerland
soulmerchant's Avatar
MC requires three major things - correct loading, (much) more gain and (very) good shielding from RF interference.
MM is in some ways much easier: the loading is pretty much fixed, requires less gain than MC (which is also pretty much fixed), and (usually) less attention to shielding.
However MM requires much more care to be taken with regard to input capacitance - this includes valve/tube miller capacitance, valve/tube socket capacitance, connector capacitance and all cable capacitances.
When it comes to noise floor, MC should beat MM pretty much all the time. I only ever attempted noise floor measurements on MM carts (that spreadsheet from Sy is very useful). However due to all the finicky implementation, I prefer MM over MC these days. Just make sure input miller capacitance is low enough and be careful with the connections, etc. for them. They tend to be much cheaper than MC too.
I sold pretty much all the MC carts I had a couple of years ago and have not looked back.
Old 18th April 2019, 01:35 PM   #32
kodabmx is offline kodabmx  Canada
Affordable triode connected sweep tube amps.
MC is beyond the point of diminishing returns IMHO.
I use a Pickering 625 cart with a line contact stylus and it rivals the Ortofon 2M gold for less than 1/2 the cost.
Old 20th April 2019, 01:31 AM   #33
Aladding is offline Aladding  China
Modern MM catridges have obviously improved performance, such as frequency response comparable to MC at much lower price, thanks for advancements of magnet technologies.
But MC catridges can still offer better dynamics and THD, if the signal can be processed in DC mode amplifier. That means that the phono amp will be configured to work in DC mode, with MC catridge directly coupled to the phono amp and the phono amp processing the signal as a DC amp, eliminating any and all AC coupling elements on the signal path, such as step-up transformer, coupling capacitor or output transformer.
Then it will sound, in some cases, like a DSD player. Don't know it's a good or bad omen.
Old 20th April 2019, 04:55 PM   #34
Guerilla is online now Guerilla  Denmark
This noob always read that MC had higher price an distotion against itself compared to MM
active v.s. passive phonoHide this!Advertise here!
Going from passive to active tri amp? krivium Multi-Way 10 21st September 2015 09:55 AM
Will phono pre > passive pre > amp work well enough? soldersmoker Analog Line Level 12 3rd September 2013 06:15 PM
Phono transformer VS Active phono pre ckwong99 Analogue Source 0 2nd November 2005 04:35 AM
dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order Hybrid fourdoor Multi-Way 3 11th July 2004 09:16 PM
Passive vs Active I/V HeadSh0T Digital Source 1 7th May 2003 10:12 PM
Copyright ©1999-2019 diyAudio
