Simple Hybrid tube amplifier with MOSFET output
Old 11th July 2019, 04:22 AM   #31
flancfuster is offline flancfuster  Europe
Working on output stage.
"Without music, life would be a mistake." - Nietzsche
Old 11th July 2019, 01:36 PM   #32
bandol83 is online now bandol83  France
Hi flancfuster,
If you want to make your own PCB, I suggest you to use the version 5 HD which was modified with Hugh recommendations for the Mu-follower stage instead of the SRPP ! I didn't test it yet, but I had problem with the SRPP version
Rgds,
Marc
Old 11th July 2019, 11:07 PM   #33
e_fortier is offline e_fortier  Canada
e_fortier's Avatar
Very nice work Marc !!
As always - the last built gizmo is the very best
Old 11th July 2019, 11:08 PM   #34
Marc on the schematic attached, 0.1uF couling caps are missing. I can see only 0.22uF. Are they required?
Originally Posted by bandol83 View Post
Hi flancfuster,
Rgds,
Marc
Old 13th July 2019, 09:29 AM   #35
kees52 is offline kees52  Netherlands
Nice amp, I have done also with that current source however that is a tube, and I have the mosfets dc coupled to the tubes, that is possible with a dc servo and a pauze into the speaker protection, I set it on 1 minute so tubes are warm before switch on. I did not use feedback and I am not a fan of mosfet relais between speaker.
Old 13th July 2019, 11:01 AM   #36
DC coupled? I would like to try that. Can you share the schematic of your project?
Old 13th July 2019, 11:40 AM   #37
Here is a schematic of a all plate follower, this one dit sound so open that I was suprised, (without feedback) when use a higher mu preamp tube you need to connect feedback.
search on mine name here I have more somewhere, I am on a other pc now, programming so I can not send.
regards
Old 13th July 2019, 10:09 PM   #38
Thanks, I'm looking on other threads started by you.
regards
Simple Hybrid tube amplifier with MOSFET outputHide this!Advertise here!
Tube/Mosfet 100W Hybrid Amplifier apexaudio Solid State 145 15th July 2015 09:36 PM
Tube(6N8P/6SN7) + MOSFET Hybrid Hifi Amplifier Kit/Board siliconray Siliconray Online Electronics Store 7 13th January 2013 01:09 PM
MOSKIDO - Hybrid Tube/MOSFET Amplifier Kashmire Pass Labs 7 22nd September 2011 08:30 PM
Hybrid Tube / Mosfet Amplifier poynton Tubes / Valves 8 10th August 2007 05:32 PM
Copyright ©1999-2019 diyAudio
