Valvewizard phono diode function and elimination
Old 12th April 2019, 03:48 PM   #31
leadbelly is offline leadbelly  Canada
leadbelly's Avatar
Originally Posted by Osvaldo de Banfield View Post
Call it as you want, but from simple regens to entire radar systems were working pretty fine without any kind of semiconductor, so why not a simple audio amplifier can't?
Why should your view, opinions, bias, etc. force others to do things in a way they don't want to? Why are you so dug down that you can't enjoy what you see in common because what you see differently drives you crazy? It's just a hobby.
Wise men speak because they have something to say; Fools because they have to say something. Plato
Old 12th April 2019, 04:37 PM   #32
mashaffer is online now mashaffer  United States
I like the idea of using diodes. If I understand them correctly they should not produce any noise or distortion when not conducting so that the are inert in normal operation.
It might be fun to use strings of LEDs (protected by Si diode against reverse bias) for a visual indicator of being activated.
If you are not a part of the Solution... you are a part of the Precipitate
Old 12th April 2019, 10:51 PM   #33
Merlinb is offline Merlinb  United Kingdom
Merlinb's Avatar
Tubes are in the Earth a century ago than SS, I cant understand how did they was working all that time without SS help.
Because they did not plug those tube regens into low-voltage components like opamps. The diodes are to protect modern low-voltage components.
Buy my tube hi-fi book! www.valvewizard.co.uk
Old 13th April 2019, 01:41 AM   #34
Would this be right? That is to accomplish the clamping and protect the LED...
Old 13th April 2019, 01:59 AM   #35
GoatGuy is offline GoatGuy  United States
GoatGuy's Avatar
We're asking a lot from those LEDs in series with reversed Zeners.
Just saying,
GoatGuy ✓
John Curl's Golden Rule…: 100 kHz bandwidth, 3 μs risetime, 100 W mean output, 100 V/μs slew rate, 2 Ω dynamic load, 20 amp min current source/sink
Old 13th April 2019, 02:04 AM   #36
Just saying,
GoatGuy ✓
Probably not worth it just for the bling.
Old 15th April 2019, 12:52 PM   #37
Osvaldo de Banfield is online now Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Where and when I wrote that he must do what I said?
Call for medical aid, please. You are ill.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 15th April 2019, 03:09 PM   #38
leadbelly's Avatar
So, you only offer non-binding criticism of SS used in tube circuits? Why say anything then? I am not trying to attack you, in fact, that would be the opposite of my point
Valvewizard phono diode function and eliminationHide this!Advertise here!
bandpass port resonance elimination scott68 Subwoofers 41 15th July 2017 07:09 PM
crossover elimination hewo Multi-Way 17 1st August 2015 05:41 PM
what diode should i use for the LM4780 mute function? TiGeRGuY Chip Amps 16 26th July 2010 11:20 AM
78xx + FAT capacitors = ripple elimination?? smellygas Power Supplies 10 14th September 2009 10:05 PM
Copyright ©1999-2019 diyAudio
