Replacing valves.
Replacing valves.
Old 15th April 2019, 12:24 PM   #31
kodabmx is online now kodabmx  Canada
Affordable triode connected sweep tube amps.
Replacing valves.
No difference really... The grid is still grounded in the first one albeit through a 100k resistor. This resister along with another and a cap can be used for Broskies' Aikido PS noise nulling. I removed it since I don't use Aikidoing.
I find this circuit will work from about 200V to 350V without changes but the higher end of the voltage scale is preferred if you have it. The above example using 280V is based on an eBay 12V to 280V DC boost converter.
I've also changed the 1M on the output to 100k.
Old 16th April 2019, 09:09 AM   #32
Boydk is offline Boydk  Denmark
Thanks BearBMX
Valuable info. I bought a bunch of these boost converters (ideal price), so
Im going to give this a GO in the near future.
Thanks again for all your info
Replacing valves.Hide this!Advertise here!
replacing kt66 valves solderon Tubes / Valves 9 19th April 2012 12:11 PM
Valves Professor smith Pass Labs 47 10th June 2009 10:58 PM
replacing op-amps with thermionic valves jenks Tubes / Valves 2 25th March 2008 01:45 PM
Replacing Valves Leak Stereo 20 pubrunner2000 Tubes / Valves 6 15th December 2007 01:01 AM
Replacing Valves Tom Smithson Tubes / Valves 1 19th October 2004 02:20 AM
Copyright ©1999-2019 diyAudio
