Grounding Question
Grounding Question
Old 14th March 2019, 05:28 AM   #11
Chris Hornbeck is offline Chris Hornbeck  United States
Chris Hornbeck's Avatar
Originally Posted by Merlinb View Post
What an excellent piece! Thanks very much for posting this; it'll be where I'll point folks from now on.
All good fortune,
Chris
"A marveilous newtrality have these things mathematicall and also a strange participation between things supernaturall, immortall, intellectuall, simple and indivisible, and things naturall, mortall, sensible, componded and divisible." - John Dee
Old 14th March 2019, 06:11 AM   #12
Diabolical Artificer is offline Diabolical Artificer  United Kingdom
"What an excellent piece! Thanks very much for posting this; it'll be where I'll point folks from now on." Merlin's site is invaluable for builders of valve amps, I'd have struggled without it.
Andy.
Old 14th March 2019, 07:12 AM   #13
Issues of "grounding" are subtle, maybe in some large part because we believe schematics, where elephant-in-the-room assumptions are the usual case. Merlin B's piece is crystal clear in breaking down the assumptions into good mental models. Once you have a good (and real) model, you can fly on your own.
Bob Cordell's book (highest possible recommendation) additionally discusses the signal ground to chassis ground connection in detail. And JNeutron has posted some ground-breaking (NPI) next-gen thoughts about system wiring issues in the John Curl Blowtorch thread, mostly lost in the noise there, but well worth the effort.
All good fortune,
Chris
Old 14th March 2019, 03:24 PM   #14
David Davenport is offline David Davenport  United States
Audio Component Grounding and Interconnection right here on diyAudio.
Grounding QuestionHide this!Advertise here!
Grounding Question bigbillc Pass Labs 35 22nd September 2017 07:52 PM
SPP Grounding Question reaper996 Tubelab 1 25th June 2016 06:32 PM
Grounding question... Pooch Tubelab 5 8th May 2014 10:56 PM
OPT grounding question Nihilist Tubes / Valves 16 2nd June 2009 02:06 AM
grounding question skyraider Chip Amps 1 9th March 2004 09:12 AM
Copyright ©1999-2019 diyAudio
