noDAC DHT output stage
Joined 2009
OK thanks.
I have with transformer no filter no noise but a little bit distorsion(0.8%).
With filter and transformer i had 0,1% distorsion. With isolator, filter and tube cathode follower i have 0.04% distorsion. No noise. Isolator has it ones power supply.
I understood correctly that you don't use the filter & the isolator, are you using only the transformer?
Joined 2009
I'm using attached schematic but in place OPT I use the OPT as choke connecting all primary an output cap between the choke & plate, I don't know exactly the plate voltage but I guess something between 140-145V.
