noDAC DHT output stage
Old 6th March 2019, 11:38 PM   #41
Hearinspace is offline Hearinspace  Canada
Thanks !
Old 7th March 2019, 10:55 AM   #42
merlin el mago is offline merlin el mago  Europe
merlin el mago's Avatar
You're welcome.
@ abraxalito
Done the filter yesterday and enjoyed all the evening & night listening music, a big thanks again.
About step up transformers I guess I need 1:1.27 my calculations:
0.56Vrms = 1.58Vpp
0.71Vrms = 2Vpp
So I need to increase 0.15Vrms to reach the 2Vpp, it's OK.
Also I need an OPT with primary impedance of 50 Ohm & a secondary of 63.5 Ohm
Are my calculations OK?
Old 15th March 2019, 10:06 PM   #43
Nobody?
Old 15th March 2019, 11:17 PM   #44
Tjj226 is offline Tjj226
Originally Posted by merlin el mago View Post
You're welcome.
@ abraxalito
0.56Vrms = 1.58Vpp
0.71Vrms = 2Vpp
Are you sure you want 2vpp? Most digital signal sources are 2v RMS.
I would just go with a plain old 1:2 step up transformer. That would give you 1v rms out.
Old 15th March 2019, 11:53 PM   #45
I'm sorry yes for 2Vrms, so I will need 1:4 ratio, primary 50 ohms & secondary 200 ohms, that's?
Old 16th March 2019, 12:33 AM   #46
kokoriantz is offline kokoriantz  Lebanon
The impedance ratio is the square of the transformer's winding ratio . Most ready made transformers for audio are 600 ohms . What you need is 600:10k . See on Aliexpress .
Old 16th March 2019, 11:25 AM   #47
Yes I forgot thanks, I need a primary impedance of 50 ohms because is the output impedance of Amanero and the input/output impedance of the 4th order low pass filter so I need a custom made OPT 50:833 ohms 1:16 ratio?
What have I to look for: Line input transformer or Step-up MC transformer?
noDAC DHT output stageHide this!Advertise here!
noUSB and noDAC - ultimate DSD player Presley Digital Line Level 41 19th May 2017 07:07 AM
opamp plus driver stage and output stage with its own supply, what could happen? Mihkus Chip Amps 165 8th February 2014 11:14 AM
what happens if the voltage of the output stage exceeds the VAS Stage in LME amps rhythmsandy Solid State 0 13th October 2013 06:03 PM
Common emitter stage driving low hfe output stage Fusion916 Solid State 1 20th December 2012 05:05 PM
Help with input stage driver for EL84 output stage AudioGeek Tubes / Valves 2 20th March 2010 01:38 AM
Copyright ©1999-2019 diyAudio
