noDAC DHT output stage
Old 3rd March 2019, 06:38 PM   #21
merlin el mago is offline merlin el mago  Europe
merlin el mago's Avatar
What choke are you using now, amorphous?
Old 3rd March 2019, 07:16 PM   #22
Koifarm is offline Koifarm  Netherlands
Koifarm's Avatar
Originally Posted by merlin el mago View Post
Could you elaborate why you chosen two corner frequencies and what's the final Fc?
Fc about 37khz at 1260ohm output impedance.
Old 3rd March 2019, 07:18 PM   #23
Isn't too low? Did you heard noise with the Fc higher?
Old 3rd March 2019, 07:24 PM   #24
Koifarm's Avatar
I have with transformer no filter no noise but a little bit distorsion(0.8%).
With filter and transformer i had 0,1% distorsion. With isolator, filter and tube cathode follower i have 0.04% distorsion. No noise. Isolator has it ones power supply.
Old 3rd March 2019, 07:25 PM   #25
What transformer do you use?
Old 3rd March 2019, 07:40 PM   #26
Koifarm's Avatar
Lundahl LL1521B
Old 3rd March 2019, 07:44 PM   #27
Have gain?
Old 3rd March 2019, 07:51 PM   #28
Raj1 is offline Raj1  United Kingdom
ultranalog: CD enhancer II
Old 3rd March 2019, 07:55 PM   #29
Koifarm's Avatar
Have gain?
2.3 times step up.
Old 3rd March 2019, 08:01 PM   #30
Thant's very good numbers, could I ask how much cost?
noDAC DHT output stageHide this!Advertise here!
noUSB and noDAC - ultimate DSD player Presley Digital Line Level 41 19th May 2017 07:07 AM
opamp plus driver stage and output stage with its own supply, what could happen? Mihkus Chip Amps 165 8th February 2014 11:14 AM
what happens if the voltage of the output stage exceeds the VAS Stage in LME amps rhythmsandy Solid State 0 13th October 2013 06:03 PM
Common emitter stage driving low hfe output stage Fusion916 Solid State 1 20th December 2012 05:05 PM
Help with input stage driver for EL84 output stage AudioGeek Tubes / Valves 2 20th March 2010 01:38 AM
Copyright ©1999-2019 diyAudio
