noDAC DHT output stage
Old 3rd March 2019, 11:34 AM   #11
kokoriantz is offline kokoriantz  Lebanon
Why not isolating transformer 10k/40k (about 40$ a pair on Aliexpress) and cathode follower as 6N1p for example?
Old 3rd March 2019, 11:36 AM   #12
merlin el mago is offline merlin el mago  Europe
merlin el mago's Avatar
I want DHT, yes I'm contemplating also a step up 1:2 transformer without DHT output stage, but I'm lost looking for proper step up transformer?
Old 3rd March 2019, 11:42 AM   #13
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Instead of building some half baked DHT output for this very dubious project, why don't you build a no-compromise DHT preamp which will work with the nodac but also work with any future projects too? It will very likely be transformer coupled and this will also take care of filtering >100kHz.
Old 3rd March 2019, 11:44 AM   #14
I have one: 26 preamp, but will be great to have the same gain like the Valve Itch phono preamp.
My 26 is choke loaded, I prefer the sound over OPT.
Old 3rd March 2019, 04:23 PM   #15
Koifarm is offline Koifarm  Netherlands
Koifarm's Avatar
The filter has first corner frequency at about 23khz and second at 64khz. The 1k5 resistance i tune the transformer i had behind the filter.
Old 3rd March 2019, 04:24 PM   #16
Tjj226 is online now Tjj226
I will offer 3 ideas.
1: If all you have to do is basically double the voltage, I would just use a step up transformer. A step up transformer is going to do a better job than a tube ever could.
2: If you have to use a tube and it has to be a DHT, I would look into the 300b. Theoretically it could be configured to give you 600 ohms for the output impedance which might have some neat applications.
3: If you want a tube, but would be willing to consider an indirectly heated triode, then a 6as7g might be neat *shrug*
I would just shoot sowter an email. If you show them what you are up to, they can recommend you a decent transformer.
Old 3rd March 2019, 04:49 PM   #17
I supposed did you used a 4th order low pass filter.
1: Interested what I don't want a custom step up transformer to avoid high prices.
2: 300B is a expensive DHT & I guess I didn't need that gain.
3: Used the 6AS7 as output in a headphone amp but I prefer DHT.
See post 19 mine answer 1
Could you elaborate why you chosen two corner frequencies and what's the final Fc?
Old 3rd March 2019, 06:26 PM   #18
analog_sa's Avatar
Curiously, so did i. At least while being stuck in the Lundahl swamp
Old 3rd March 2019, 06:29 PM   #19
Yes I use LL1660 as choke as suggested by Andy Evans connecting all the primaries
Old 3rd March 2019, 06:34 PM   #20
analog_sa's Avatar
Curiously this is something else i've tried a long time ago. A proper choke, such as the 1668 slaughters the 1660 in this position. Unlike the transformer used as a choke, the proper choke allows for unmolested square waves too.
noDAC DHT output stageHide this!Advertise here!
noUSB and noDAC - ultimate DSD player Presley Digital Line Level 41 19th May 2017 07:07 AM
opamp plus driver stage and output stage with its own supply, what could happen? Mihkus Chip Amps 165 8th February 2014 11:14 AM
what happens if the voltage of the output stage exceeds the VAS Stage in LME amps rhythmsandy Solid State 0 13th October 2013 06:03 PM
Common emitter stage driving low hfe output stage Fusion916 Solid State 1 20th December 2012 05:05 PM
Help with input stage driver for EL84 output stage AudioGeek Tubes / Valves 2 20th March 2010 01:38 AM
Copyright ©1999-2019 diyAudio
