6SN7 Mu follower or cathode follower?
Old 15th November 2019, 11:06 PM   #81
N101N is offline N101N
Self-delusion is far more addictive than Single Ended Class-A-Holism!!!
Old 16th November 2019, 02:54 PM   #82
Lingwendil is offline Lingwendil  United States
Lingwendil's Avatar
Originally Posted by Wavebourn View Post
Wow, we have a new Guru!
On another note- this thread lit a fire under me. Time to dig out a few clear-top 6FQ7's and build a mu follower. I need to build a crossover and baffle step compensation preamp anyway. Maybe I'll use a 6N1P or 6DJ8 as the top tube?
Check out My 6SN7 Push-pull Flea Amplifier project! PCB COMING SOON!
Old 16th November 2019, 05:10 PM   #83
jhstewart9 is online now jhstewart9  Canada
jhstewart9's Avatar
Default Search shews no threads started by N101N
Strange for a poster with no originality to display!
Or queries??Already knows all.
Old 16th November 2019, 07:32 PM   #84
Wavebourn is offline Wavebourn  United States
Anatoliy Lisovskiy
Wavebourn's Avatar
Use MOSFET - based Gyrator, like I do. Let Gurus hiss and spit.
Here is my Preamp+ PCB, with Gyrator load of the triode, CCS load of cathode follower, and relay shunting of outputs.
!!!Warning!!!
Single Ended Class-A-Holism is addictive!!!
Old 16th November 2019, 07:35 PM   #85
Anatoliy Lisovskiy
Wavebourn's Avatar
He reminds me one more personage, I would not say his name. Everything that he can not understand is bad.
!!!Warning!!!
Old 17th November 2019, 01:11 AM   #86
PRR is offline PRR  United States
PRR's Avatar
This seems like a start of a Personal Attack.
Don't go there.
Also: thread start count may not be a valid metric. Some otherwise brilliant people can't find the New Thread button. Some don't feel a need to start a thread for every good thought, but weave them into existing threads.
Old Today, 12:55 AM   #87
The mu follower is basically a common cathode amplifier
It is definitely not. It is a compound with new and fundamentally different properties and behavior.
increased the dynamic load resistance perceived by the lower device, which as you are no doubt aware will greatly increase linearity and gain.
On the contrary, distortion will greatly increase, but it is not simply a matter of increased impedance, there is much more to it.
I'm not even a huge user of the mu follower, but it's a great single ended (yes, this is not a blanced, or push-pull type of stage!) circuit
Did Morgan Jones say so? But no, the signal is balanced (not referred) to ground.
There is no "balanced action, and the harmonic content is very similar to a common cathode that is loaded with an equivalently selected load to the reflected resistance shown by the cathode follower and load resistor.
The harmonic content is very dissimilar to a common cathode, only odd harmonics being produced as one of many negative consequences of the balanced state.
Morgan Jones' book has obviously not helped you towards a better understanding of the present topic, which proves to be too elusive to treat for that genre of authors.
Many amplifiers proudly announced to be single ended are actually out-and-out balanced. Most people have bad taste, poor ability to judge sound quality and perceive the single ended sonic character as a nuisance. A "clean" sound is more widely preferred, that is to say, when a small portion of the input signal is transferred. It is efficiently accomplished by designing amplifiers as a voltage regulator / oscillator consisting of various balanced stages and techniques imported from the industrial sphere.
I do use the push-pull topology, but I don`t call it single ended or low distortion.
Old Today, 12:57 AM   #88
Tell us what you understand.
6SN7 Mu follower or cathode follower?Hide this!Advertise here!
Source follower VS white cathode follower hellokitty123 Tubes / Valves 12 28th April 2018 12:16 AM
Cathode follower PA Driver in a cathode biased amp stephenl5 Tubes / Valves 6 19th April 2015 03:27 PM
6sn7 mu-follower merlin el mago Tubes / Valves 25 22nd April 2013 08:32 PM
CCs plate load for mu follower 6sn7 duderduderini Tubes / Valves 4 8th November 2007 01:40 PM
Question about direct coupling a anode follower into a cathode follower. G Tubes / Valves 45 29th July 2004 07:47 PM
Copyright ©1999-2019 diyAudio
