6SN7 Mu follower or cathode follower?
Old 8th November 2019, 01:55 PM   #21
rhythmsandy is offline rhythmsandy
Im using the following. The B+ gnd is connected to the signal ground which is not mentioned in the pcb.
Old 9th November 2019, 01:04 PM   #22
N101N is online now N101N
The mu follower is associated with high distortion. If distortion matters you should adopt the circuit in post #4.
Old 9th November 2019, 01:17 PM   #23
rongon is offline rongon  United States
rongon's Avatar
That's odd. Everywhere I've seen, the mu follower is associated with *low* distortion (and comes close to achieving gain equal to the mu of the tube, hence its name).
Old 9th November 2019, 02:32 PM   #24
Can anyone tell me anything wrong in the above PCB layout?
Old 9th November 2019, 02:37 PM   #25
Lingwendil is offline Lingwendil  United States
Lingwendil's Avatar
By who? The mu follower is a very low distortion gain topology when implemented correctly, and it is rather easy to do right. What testing have you found to the contrary?
6SN7 Push-pull Flea Amplifier PCB files are now available!
Old 9th November 2019, 02:42 PM   #26
rongon's Avatar
Can you post which specific schematic is the basis for that specific PCB layout, with corresponding parts reference numbers shown? (R1, C3, etc.)
Old 9th November 2019, 02:48 PM   #27
Diabolical Artificer is offline Diabolical Artificer  United Kingdom
I'd sort your power supply out before you do anything. Find a suitable load and scope it. Nailing the hum issue should be first priority.
Andy.
Old 9th November 2019, 03:39 PM   #28
baudouin0 is offline baudouin0
The other option is the bootstrap follower. You feed the output of the cathode follower through a cap back to a split anode load resistor. Advantage low distortion and rejection of the HT supply.
Old 9th November 2019, 04:05 PM   #29
schematic attached
Old 9th November 2019, 04:07 PM   #30
Andy.
Im using single bridge 5010 followed by CLC 220uF/450V , 2H , 220uF/450V 470k shunt at the output.
Two AC terminals for the heater supply is joined via two resistors each 100ohm and the joint of the two resistors connected to the power ground.
6SN7 Mu follower or cathode follower?Hide this!Advertise here!
Source follower VS white cathode follower hellokitty123 Tubes / Valves 12 28th April 2018 12:16 AM
Cathode follower PA Driver in a cathode biased amp stephenl5 Tubes / Valves 6 19th April 2015 03:27 PM
6sn7 mu-follower merlin el mago Tubes / Valves 25 22nd April 2013 08:32 PM
CCs plate load for mu follower 6sn7 duderduderini Tubes / Valves 4 8th November 2007 01:40 PM
Question about direct coupling a anode follower into a cathode follower. G Tubes / Valves 45 29th July 2004 07:47 PM
Copyright ©1999-2019 diyAudio
