Anthem Pre1 failure
Anthem Pre1 failure
Old 16th February 2019, 03:11 PM   #1
tlcconsultant is offline tlcconsultant  Italy
Default Anthem Pre1 failure
Hello,
After 20 years of operation, my ANTHEM PRE 1 preamplifier is failure. The fuse in the power supply is blown. Does anyone have an electric schematic? I tried to contact Anthem and Partconnexion but I had no answers.
Thank you
Old 17th February 2019, 03:43 AM   #2
Tjj226 is offline Tjj226
Has the fuse blown once, or does it keep blowing new fuses?
Old 17th February 2019, 08:22 AM   #3
Hello,
The new fuse also burns. I'll have to do checks.
For this reason I would like to have a schematic diagram.
Thank you.
Old 17th February 2019, 08:50 AM   #4
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
You can do some simple checks without any schematics.
Disconnect all secondary wires from the mains transformer and try again. If the fuse still blows then the transformer is shot.
Does it have semiconductor or valve rectifiers ?
Old 17th February 2019, 10:08 AM   #5
if it were, such as replacing the transformer without the data of the electric diagram?
In the power supply module there are a GZ34 and two solid state graetz rectifier (4 integrated diodes each).
Old 17th February 2019, 11:40 AM   #6
petertub is offline petertub  Sweden
Anthem Pre1 failure
One could as a starter examine the power caps, startig with the B+ ( high voltages ).
One quich test is to pull the GZ34 and see if the fuse blows. If not you could
follow the B+ chain where the power caps are a suspect.
My home is at www.tubular-well.se
Old 18th February 2019, 02:53 PM   #7
We're not asking you to replace anything yet, get getting a feeling as to where the fault might lie.
Old 18th February 2019, 04:02 PM   #8
Today and tomorrow I will certainly not have time to do some tests. As soon as I start I will communicate the results here. For the moment, I thank all those who answered me
Anthem Pre1 failureHide this!Advertise here!
anthem pre-1 audio king Tubes / Valves 0 6th September 2014 02:38 AM
Anthem D2v Mod steven2583 Analog Line Level 1 15th October 2011 12:30 AM
Anthem Pre 2L: Potentiometer markmay Analog Line Level 2 27th May 2010 09:41 PM
Anthem Amp 2 debugging help ronenash Solid State 20 23rd April 2010 01:09 PM
Anyone familiar with Bel Canto Pre1? john65b Solid State 5 29th March 2008 11:29 PM
Copyright ©1999-2019 diyAudio
