12AT7 for 12AX7 in preamp
Old 11th February 2019, 05:14 AM   #21
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Hi, i would suggest that you consult the RCA tube databook, RC30 and look at the tables on RC couples mplifiying stages, those tables contain values of plate load resistors , grid resistors and cathode bias resistors for a give B+ and voltage gain...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 11th February 2019, 09:24 AM   #22
awkwardbydesign is offline awkwardbydesign  England
Thanks. I've downloaded it; I'll see if I can make sense of it.
Originally Posted by nigelwright7557 View Post
I have never got on very well with 12ax7's.
Always ended up using a different model like the 12au7.
It seemed to be more stable and less noisy.
I have used 2 12ax7's halves in series and the tube just fed back on itself.
When I look around there seems to be plenty of amps with the halves in parallel, maybe they found the same problem ?
Having said that 2 12ax7 halves in series is around 10,000 gain so not surprising it was unstable !
You may be right, and it has more gain than I need, but I don't have the experience (knowledge) to change things by myself.
ABD.
12AT7 for 12AX7 in preampHide this!Advertise here!
12AX7 vs 12AT7 vs 12AU7 cl1238 Tubes / Valves 22 27th February 2016 05:05 AM
12ax7/12AT7 Recommendations jim1961 Tubes / Valves 166 3rd May 2012 11:07 PM
Can I do that subs 12ax7 with 12at7 tony Ma Analog Line Level 6 25th July 2011 10:43 AM
12AU7/12AT7/12AX7 preamp schmatic needed Sal Brisindi Tubes / Valves 6 17th October 2009 04:48 AM
12AU7 or 12AT7 instead of 12AX7 ? Gubby Tubes / Valves 5 26th June 2004 12:31 AM
Copyright ©1999-2019 diyAudio
