EL84 ECC88 pp pcb
EL84 ECC88 pp pcb
Old 22nd January 2019, 05:37 PM   #11
huggygood is offline huggygood  France
connected to H1 and H2 (heating)
Old 22nd January 2019, 07:22 PM   #12
popilin is offline popilin  Argentina
popilin's Avatar
Originally Posted by Kay Pirinha View Post
Supposedly not at all. 'Cause without being fed they simply won't do anything .
Best regards!
If you take the trouble to read more carefully, you will see that LEDs/Resistors array is connected between H1 and H2, supposedly heater voltage.
Some people like the glow of a blue LED under the valve.
I'll pass, thank you.
I do not suffer from insanity, I enjoy every minute of it. - Edgar Allan Poe
He has the most who is most content with the least. - Diogenes of Sinope
Old 22nd January 2019, 08:46 PM   #13
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
I've written above that I can't barely read anything in this schematics.
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 22nd January 2019, 10:28 PM   #14
2stuffed is offline 2stuffed  Australia
EL84 ECC88 pp pcb
Thanks for your replies and help, I didn't put the LEDs in and there's no room on the pcb to change anything ,not with my fat fingers anyway. I might try another brand of pcb . It's fun to find out all this stuff.
thanks
EL84 ECC88 pp pcbHide this!Advertise here!
ECC88 For LTP bimo Tubes / Valves 14 5th November 2015 12:48 PM
EL84 driving EL84 SET with fixed bias cotdt Tubes / Valves 13 16th March 2014 03:18 PM
FS: EL84 EI Yugoslavia & EL84 Tungsram NOS Bulk radiostar Swap Meet 3 29th January 2012 09:46 AM
ECC88 Help rhysh Tubes / Valves 2 1st December 2008 11:52 PM
OTL ECC88 amp Tyimo Tubes / Valves 13 16th February 2005 05:40 PM
Copyright ©1999-2019 diyAudio
