Bootstrapping
Bootstrapping
Old 11th January 2019, 02:09 PM   #21
mashaffer is offline mashaffer  United States
Hmmm... as I diddled with that circuit more it appears that I can use 12AY7s in both locations and still have adequate gain. So far however I have only been able to get bass output up to 15dB above the 1Khz level (IIRC it should be 20dB) but the mid band gain is about 45dB which should be about right for MM I think. 10KHz is within 1dB of spec at -12dB.
BTW, I did run some PSRR simulations using the original AX7-AY7 circuit. I applied a PS with 1mV of 120 hz ripple (actually a sine wave). Input signal was 5mV. I ran the circuit both with the bootstrap connected and disconnected. I ran an FFT on the resulting 1kHz sine wave output. Since output level also changed I compared the difference between the fundamental and the 120 hz noise for both cases. The bootstrap did improve the ratio slighty being about 3dB better with the bootstrap.
I also ran a simulation of a 6SN7 linestage with similar loading and that looks promising.
The only reason I drive the 91 Colony Park is that I can't afford a 65. Me old school? Couldn't be.
Old 11th January 2019, 05:47 PM   #22
MarcelvdG is online now MarcelvdG  Netherlands
Originally Posted by mashaffer View Post
Thank you.
So to minimize noise contribution we want highish gm for the followers.
Noise wise it is mainly the gm of the input stage that matters, and also the 1/f noise of the input stage.
For amplifiers with RIAA correction, I once came up with this table for the optimal anode currents. The ECC83 (12AX7) and ECC88 (6DJ8) values are based on Merlin Blencowe's data, the triode-connected EF86 (6267) figures on my own measurements. The noise densities are white noise densities that would result in the same integrated weighted noise as the actual noise of the triode.
I never thought about amplifiers for ceramic cartridges with less or no correction.
Old 11th January 2019, 07:33 PM   #23
Very helpful Marcel. Thank you. In your opinion which weighting corresponds more closely to what we actually hear?
Do you think the average hobbyist would understand Merlin's article well enough to make it worth purchasing it? It sounds fascinating.
Old 11th January 2019, 08:04 PM   #24
Of the various standard weightings, ITU-R 468 best matches what you hear, unweighted is the worst match and A-weighted is somewhere in between.
Regarding your second question, to me Merlin's article is very clear, but I'm a hobbyist as well as an electronics engineer. Maybe you can first check if you can follow the discussion in this thread about his article: Flicker Noise dominates triode noise in audio (AES)
BootstrappingHide this!Advertise here!
Anode Bootstrapping Thebugger Tubes / Valves 11 26th October 2016 08:39 AM
Opamp bootstrapping Athelionas Chip Amps 9 12th December 2011 04:06 PM
Bootstrapping seanvn Solid State 3 6th November 2011 09:39 AM
bootstrapping two SE transformers into a pp one? Rockmonton Tubes / Valves 8 16th November 2004 02:10 PM
Bootstrapping LM3886 xplod1236 Chip Amps 19 4th August 2004 10:49 PM
Copyright ©1999-2019 diyAudio
