Glassware Aikido All-in-One (Octal) | ACF-2 Buffer
Old 14th March 2019, 01:51 PM   #51
sunil is online now sunil  India
Originally Posted by kodabmx View Post
No, it must be LOG. I was being facetious...
50k should be fine. I use 100k as the middle ground. I used to use 1 MEG!
Old 14th March 2019, 09:24 PM   #52
Wikkid is offline Wikkid  United States
Wikkid's Avatar
Originally Posted by sunil View Post
50K looks like the perfect middle ground.
Making the BEST choice nescessitates knowing to a certainty the impedance of the source and load... Especially the load.. Knowing total cable capacitance, and input capacitance of the load, is crucial, but it's rare that one does... In most cases, you'll wind up making a "best guess" at it, since knowing cable capacitance is something most don't.... and knowing the input capacitance of the load component usually requires manufacturer giving that knowledge... and they usually don't.
The consequence of getting this wrong.... is basically creating a filter... a Bandpass RC filter.. It will prematurely roll off either the highs or the lows... depending on whether you've chosen a higher or lower pot value....
Here is a very comprehensive thread on the subject: How to determine what value Pot (attenuator)???
Old 15th March 2019, 04:06 AM   #53
alexcp is online now alexcp  United States
alexcp's Avatar
Using a log pot between the input switch and the active circuitry as a volume control forces certain compromises. You know you're in trouble when you cannot fully control something "crucial" to performance, such as the cable capacitance when cables can easily be replaced. A better choice is to design the conditionality and compromises out of the volume control, as Baxandall did decades ago. Yet, the log pot tradition holds.
Old 15th March 2019, 06:46 AM   #54
Wikkid's Avatar
My solution is to just bypass the pot altogether and use an AVC!
Tribute - The final word in audiotransformers
Old 16th March 2019, 01:32 AM   #55
kodabmx is offline kodabmx  Canada
Affordable triode connected sweep tube amps.
My solution is this:
I use one of these:Hi-End VOL / 2-Channel Relay Volume Control Board /Stereo volume board | eBay
I've tested it, and it's lowest Rin was about 1k or so. '
Here's the circuit:
I should say I've replaced the pot they give you with one of these... 1Pcs WXD3-13-2W 22K 220R Multiturn Trimming Potentiometer Variable Resistor | eBay
File Type: png Aikidoesque-6N14P-6N6P-Volume-relays.png (31.5 KB, 58 views)
Old 17th March 2019, 01:47 AM   #56
alexcp's Avatar
It seems it uses a pot plus ADC combination to control the relays. Do you experience the issue sometimes mentioned in connection with that arrangement, where the LSB of the ADC in certain pot positions is not stable and flickers between 0 and 1, so the respective relay keeps clicking even though the pot is not being turned?
Old 17th March 2019, 03:11 AM   #57
Once in a while but you just move the pot slightly.
Glassware Aikido All-in-One (Octal) | ACF-2 BufferHide this!Advertise here!
Glassware ACF-2 Aikido hum problem MrJackson Tubes / Valves 89 21st February 2019 02:15 PM
Help with Glassware ps-14 for Octal 8 Tri33 Power Supplies 0 14th April 2016 08:35 PM
Octal Aikido with gain/buffer switch? grogthegreat Tubes / Valves 7 22nd April 2015 05:13 PM
Newbie GlassWare Aikido All in One Questios George61 Tubes / Valves 20 17th December 2012 09:08 AM
Aikido Octal Preamp Glassware TCJ with regulated supplies mattattnet Swap Meet 1 4th October 2011 02:05 AM
Copyright ©1999-2019 diyAudio
