Best signal wire ...
Old 6th December 2018, 06:09 PM   #11
Lingwendil is offline Lingwendil  United States
Now with high-fructose ASSAULT-gluten!
Lingwendil's Avatar
Uh, why are you posting golden-ear audiophoolery here? Careful, the thread might get moved to the lounge, as religion (and politics) is prohibited from discussion on the forum...
Besides, we're discussing signal wiring inside an amplifier here, right? Silver wire is fine, if a bit unnecessarily expensive for the job.
That second link has some hilariously expensive snake-oil parts (RCA plugs for 299$ a set?!) recommendations.
Check out My 6SN7 Push-pull Flea Amplifier project! PCB COMING SOON!
Old 6th December 2018, 07:03 PM   #12
Blitz is offline Blitz  Germany
That was not my intend...the title was "best ..."
I used all kind of wires for signal within an amp and I am not relegious about silver vs. copper. If you want to stay reasonable, you will get excellent results with Jupiter solid core copper 0,4mm in cotton. Absolutely great stuff as well...today I would always try to stay with cotton, silk etc. But I used as well all kind of teflon coated cables, copper, silver, stranded, solid. On connector, WBT AG are very good, but you can as well use the asian Eichmann plug copies for 16$ from ebay with excellent results.
Old 6th December 2018, 07:09 PM   #13
kodabmx is offline kodabmx  Canada
In the average power amp, you could use barbed wire :P
I use these RCA connectors: 10Pcs RCA Female Jack Socket Red/Black Chassis Panel Mount Connector Ga | eBay
I use this wire: Single Conductor Cables (Hook-Up Wire) | Cables, Wires | DigiKey
YMMV, but in the average power amplifier, noise on the input isn't an issue.
Old 7th December 2018, 02:15 AM   #14
PRR is offline PRR  United States
PRR's Avatar
What does the input wire GO to? Typically a PCB, open to the same EMI influences, and laid-out for the circuit's needs. Or point-to-point (to-point to-point to-point) construction. i.e. if the inside of the chassis is "clean enough" for the PCB, any sane length of any kind wire will be fine.
People have opinions on copper, silver, etc. Personally, in DIY, I think a nice color insulation affects "sound" more.
Old 7th December 2018, 06:14 AM   #15
huggygood is offline huggygood  France
@ Blitz
Good good site !!
old school but good
Old 7th December 2018, 11:11 AM   #16
Burnedfingers is offline Burnedfingers  United States
Your absolutely right. Different insulation for each type of music you listen to. Red for rock, Yellow for Jazz and so on. So, be prepared to take the amp apart every time you change your music.
Old 7th December 2018, 11:28 AM   #17
Originally Posted by huggygood View Post
@ Blitz
Good good site !!
old school but good
You are welcome...I am always curious...what is new school ?
Old 7th December 2018, 11:39 AM   #18
DF96 is online now DF96  England
Cotton, silk etc. should always be avoided unless you sincerely believe that the dielectric makes absolutely no difference. This is because they are awful dielectrics whose properties change with the weather. Of course, if you believe that it makes no difference then you have no reason to choose them anyway.
Old 7th December 2018, 11:55 AM   #19
Hmmm...it seldomely rains in my living room and humidity is pretty constant...temperature as well...but I will observe this now more seriously...I always though that it sounds better in the winter.
Old 7th December 2018, 09:03 PM   #20
this site is old school,not what they sell
Best signal wire ...Hide this!Advertise here!
Signal leads for balanced miniDSP - 3-wire vs. 2-wire+outer braid Pallas miniDSP 2 18th April 2012 03:16 PM
What type of wire for signal in? FenderBender11 Analog Line Level 66 4th October 2011 04:00 PM
line out signal wire question fragman56 Everything Else 6 24th November 2006 02:51 PM
What kind of signal wire do you use in your DIY DAC or CDP? MGH Digital Source 54 22nd April 2006 12:10 PM
signal wire yuval Tubes / Valves 4 21st October 2002 03:26 PM
