New amp project has some hum
Old 5th December 2018, 04:16 PM   #11
DF96 is offline DF96  England
5Hz could be motorboating. Try a smaller value for the 0.22uF coupling capacitor.
Old 6th December 2018, 05:21 AM   #12
6A3sUMMER is offline 6A3sUMMER  United States
You have lots of magnetics in a small space. The Lundahls are less sensitive to fields than most, but you also have some other chokes.
This could cause hum because of power transformer, and because of filter choke getting into the other magnetics.
It could also cause magnetic coupling of the tube stages, and maybe even oscillation, like the 5 Hz.
If you look at B+ you may also be seeing line bounce, with the power line voltage jumping as loads in your house and neighbors turn on and off.
You have lots to look for.
Old 7th December 2018, 02:53 AM   #13
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
1/ Keep heater wires away from audio.
2/ Don't mount transformers next to valves.
3/ Keep input circuit as short as possible.
4/ Decouple each valve stage separately.
5/ Don't run HVAC near audio signals.
6/ Use star grounding where possible.
7/ Elevate heater centre tap to 45 VDC.
8/ Use grid stoppers close to grids..
Some of problems I found causing noise in my early designs.
Definitely not exhaustive.
PCBCAD51 download or CDROM 2019 version out now http://www.murtonpikesystems.co.uk
Old 7th December 2018, 06:37 AM   #14
Tjj226 is offline Tjj226
Well what gets me is that I have a nice perfect 300mv 60hz sine wave on the plates of the 45s on both channels.
No modulation that I can see, and it is exactly 300mv on the dot. All of the AC wires are shielded to the hilt and are grounded at only one end of the shield. The AC wires are going right past the chokes for the 45, but if I move the wires away, the hum doesn't change.
If it were something like DHT hum or imbalance, I would expect to see slight variances between each channel. But nope. Same nice clean 60hz sine wave on both channels.
Im semi suspicious of the way I have the filament transformers mounted. I have one transformer on top of the other with the steel plate in between them. I tried moving them a while back and it didn't seem to make a difference, but I will move them again and see if I don't discover something.
I have a feeling that when I figure out that issue, a lot of the other issues (5hz noise) will solve themselves.
Old 7th December 2018, 04:50 PM   #15
kodabmx is online now kodabmx  Canada
You could try running the 45 filaments from a bridge (no cap) and see if it changes to 120Hz...
New amp project has some humHide this!Advertise here!
The BiAmp (aka My LM4766 + 6p15p project, and LM1875 project.) valtra103 Chip Amps 21 4th December 2015 09:32 PM
Newby project idea for HND main project help and advice needed please WIGANWEZ Chip Amps 1 17th September 2011 05:59 PM
Newby project idea for HND main project help and advice needed please WIGANWEZ Chip Amps 0 17th September 2011 02:39 PM
CDPRO2 Group Project (open source project) BrianGT Digital Source 147 8th August 2008 12:37 PM
