New rebuild - 6F12P-6P45S Triode
Old 21st February 2019, 02:29 AM   #51
kodabmx is offline kodabmx  Canada
Affordable triode connected sweep tube amps.
So far so good. Still testing though...
Old 1st March 2019, 01:42 PM   #52
hendrixgr is offline hendrixgr
Hi.
How much power they produce and at what anode voltage in triode mode?
I know that in tetrode mode they work fine but the OPT must be about 1.6K anode to anode if i am right.
I just got 10 for 40 dollars and some sockets to use in place of the 829B just for fun!
Chris
Old 1st March 2019, 01:48 PM   #53
I'm using 350V, 80ma, 2k2 Ra-a. Calculations say they make about 40W.
The 6P45S was running 320V @ 120ma, They were good for 60W, but if you drop the load to 1k3 Ra-a, they make ~ 100W.
Alternatively, if you use 5k5 Ra-a, you make a ~25W class A amp.
Old 1st March 2019, 04:32 PM   #54
That is very encouraging information, thank you!
Chris
Old 1st March 2019, 06:49 PM   #55
Any time
New rebuild - 6F12P-6P45S TriodeHide this!Advertise here!
6F12P and 6P43P push pull triode amp. kodabmx Tubes / Valves 2 8th May 2018 06:43 PM
6f12p? crazyfrog Tubes / Valves 4 22nd January 2018 07:02 PM
Passive RIAA with 6F12P and 6N5P kodabmx Tubes / Valves 7 29th September 2016 03:57 PM
6CB6 pentodes and 12AU7 twin triode to replace 7199 in major SCA35 rebuild wa2ise Tubes / Valves 9 22nd September 2016 06:02 AM
6P45S/EL509 input capacitance in triode mode 50AE Tubes / Valves 1 10th February 2013 07:02 PM
Copyright ©1999-2019 diyAudio
