ultra linear PP 6v6 kit (dynaco A-410)
Old 16th January 2019, 08:53 PM   #31
huggygood is offline huggygood  France
i want to try with 6sn7 .
Old 16th January 2019, 11:03 PM   #32
2stuffed is offline 2stuffed  Australia
I gave the triode mode a go but it was too weak ,so I put it back to UL. The biggest change came when I found some ADZAM 6SL7GT valves from the 50's.
Old 17th January 2019, 06:44 AM   #33
what value of bias and what feedback value did you set it?
Old 17th January 2019, 08:27 AM   #34
I just built it as it was , I like the sound so I didn't change any parts. I have another one so I might put better caps in it, but that's all .
Old 17th January 2019, 10:01 AM   #35
with a pot or preamp ?
Old 17th January 2019, 10:26 AM   #36
I use a 100k ALPS pot, which is good for a CD player . When I play vinyl I use a yaqin phono stage.
Old 17th January 2019, 02:00 PM   #37
ok,thank's.
i used mine with preamp or buffer or cd player with variable output .
best result with cd player in direct
Old 18th January 2019, 08:07 AM   #38
if anyone know how to check the bias off the 6sl7 in floating paraphase ,i would like to know too
Old 18th January 2019, 04:31 PM   #39
always for my learning ,if anyone can tell me why the original schematic have is modified and what is a consequence ?
ultra linear PP 6v6 kit (dynaco A-410)-dynaco-st35-png
ultra linear PP 6v6 kit (dynaco A-410)-dynaco-st35-chinois-jpg
Old 18th January 2019, 04:56 PM   #40
I found some answers to my question but not all.
Dynaco low Power Amp
if someone wants to help me understand the changes from the original schema.
I'm struggling a bit on the classic scheme but this one, I have trouble.
ultra linear PP 6v6 kit (dynaco A-410)Hide this!Advertise here!
Ultra linear 33% vs 43%? Ryssen Tubes / Valves 10 29th June 2017 08:02 AM
Ultra-Linear Zen flg Pass Labs 9 12th December 2007 06:01 PM
EL 34 30W ultra linear GAK Tubes / Valves 70 24th November 2004 12:57 PM
An Ultra -linear question fscarpa58 Tubes / Valves 5 29th July 2004 01:28 PM
Copyright ©1999-2019 diyAudio
