PP CFB toroidy OPT
PP CFB toroidy OPT
Old 6th November 2018, 07:14 AM   #11
gregt is offline gregt  New Zealand
See thread PP amp with Toriody Transformers and 7591A
Note that schematic changed on post 28. Samples of output into 8 ohms parrelled with 1uf. I like the look of your design...but I choose the 7591a tube as this is easier to drive given that the use of CFB the drive requirements double.
Old 21st November 2018, 08:58 AM   #12
LKA is offline LKA  Europe
I modified the driver circuit. Now, first stage is a triode loaded by CCS. Additional parameters are located on the schematic.
Old 22nd November 2018, 05:43 AM   #13
some photos of assembled parts
PP1-AC-CTRL-front.jpg PP1-HDCPS-front.jpg PP1-HTPS-front.jpg PP1-HTPS-back.jpg
Old 22nd November 2018, 07:31 AM   #14
Very nice...great work
Old 22nd November 2018, 07:43 AM   #15
Thanks. In a few days OPS will be finished too. I'm currently working on driver pcb design, I hope I can send it to fabrication soon.
Old 22nd November 2018, 10:29 AM   #16
artosalo is offline artosalo  Finland
artosalo's Avatar
Why an non-linear component (1N4148) at the cathode of 1st. E88CC ?
Old 22nd November 2018, 12:57 PM   #17
Diode is optional, you can use resistor-resistor
D1 -> 470R
R5 -> 100R
R9,P6,C3 - according desired FB level
In my design (2xKT88 B+420V CFB Raa4K 40W/4R) OLG is 34dB and CLG 21dB. The driver required voltage swing is 140Vpp.
Old 22nd November 2018, 06:34 PM   #18
My understanding is that Toriodal transformers are more sensitive to DC imbalance in the output pair. John Broskie (Tubecad) proposed a Cross-Refenced Auto Bias Circuit in his thread "Blumleinís garter circuit revisited"
I will try this in my next design (also using Toriody transformers)
Old 23rd November 2018, 02:31 PM   #19
The finished output stage and associated high voltage power supply.
Old 23rd November 2018, 02:53 PM   #20
Lingwendil is offline Lingwendil  United States
Now with high-fructose ASSAULT-gluten!
Lingwendil's Avatar
PP CFB toroidy OPT
Garter bias works very well, and I use it a great deal. I like it enough that my Flea amp uses it, and to be designing a PCB for it with EL84/86 types- 6N2P/6CW5 design with toroidal outputs
Check out My 6SN7 Push-pull Flea Amplifier project! PCB COMING SOON!
PP CFB toroidy OPTHide this!Advertise here!
Canterbury Windings or Toroidy.pl? steklo Parts 7 4th October 2018 08:34 PM
Toroidy output transformer review gerrittube Tubes / Valves 4 15th May 2018 05:30 PM
FS - High Quality Toroidy Custom Transformers jmcalcada Swap Meet 0 31st March 2018 07:04 PM
Any one have good circuits to use with Toroidy's Toroidal CFB outputs? Thinker1920 Tubes / Valves 10 31st March 2018 09:21 AM
Warning about chokes by Toroidy ErikdeBest Tubes / Valves 64 4th August 2017 03:00 PM
Copyright ©1999-2019 diyAudio
