Finemet OT Trafos
Finemet OT Trafos
Old 17th October 2018, 05:30 PM   #1
waltube is offline waltube  Italy
waltube's Avatar
Default Finemet OT Trafos
Today are arrived the firsts FINEMET C nucleus from Hitachi distributor.
Three types for different use, one p-p, one SE and one fro MC step up.
Soon I will have the protos to check and the intention, if they seems fine, is to produce a line of trafos.
Walter
ps: it is funny that I am a Hitachi employee ( on computer company inside the Hitachi galaxy)
Old 17th October 2018, 06:44 PM   #2
euro21 is offline euro21  Hungary
Finemet OT Trafos
Are you sure that these cores are Finemet (nanocrystalline) ones?
AMCC-200 core is METGLAS amorphous alloy (2605SA1 type).
Old 17th October 2018, 07:39 PM   #3
waltube's Avatar
Both types are under same Hitachi catalog, AMCC Series cut core / Finemet F3CC Series cut core.
In the order there are both types, the biggest for power and the little for step up (F3CC008)
For the moment
Walter
Old 18th October 2018, 12:29 PM   #4
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Looks very nice Walter.
Old 18th October 2018, 01:39 PM   #5
RajkoM is offline RajkoM  Bosnia and Herzegovina
RajkoM's Avatar
Nice. I follow thread.
Old 19th October 2018, 10:34 AM   #6
Alexnaumov is offline Alexnaumov
Fine Hitachi cores. Could you please make the close-up photo of the cut quality for this bigger Metglas ?
Old 19th October 2018, 06:11 PM   #7
waltube's Avatar
Ok
give me some time. Now they are by my friend who has all the tools to wound the trafos.
We are preparing a test set up to check them in deep, the way is the one I described time ago, the "reverse way" that is, in my opinion, the best and efficent way to check the OT trafo
OPT Characterization
Walter
Old 25th October 2018, 03:15 PM   #8
waltube's Avatar
Here the photo of two of the nucleus arrived
Now work in progress
Walter
Old 25th October 2018, 04:17 PM   #9
GoatGuy is online now GoatGuy  United States
GoatGuy's Avatar
Are your transformers going to be "double C" type? (i.e. will you be using 4 half-cores to produce a transformer?) The 'binding' of the magnetic field of your windings would be stronger if you use the cores that way.
Just saying,
GoatGuy
John Curl's Golden Rule…: 100 kHz bandwidth, 3 μs risetime, 100 W mean output, 100 V/μs slew rate, 2 Ω dynamic load, 20 amp min current source/sink
Old 25th October 2018, 04:39 PM   #10
DF96 is offline DF96  England
Would that be the 'reverse way' using the wrong impedance on the primary, as pointed out by timpert in that thread and demonstrated by him using both simulation and measurements?
Finemet OT TrafosHide this!Advertise here!
Teramoto Finemet Transformer for AK4490 DAC MrJoMe80 Swap Meet 0 20th June 2018 02:47 PM
50w PP OPT - Finemet or HiB Pegasus123 Tubes / Valves 2 14th April 2018 11:05 PM
Finemet cut core coils for passive crossovers marco_gea Multi-Way 3 8th November 2017 04:38 PM
Signal Transformers Finemet Core a1uc Swap Meet 0 23rd June 2016 01:36 AM
Premium Finemet Transformers Hal Teramoto Feastrex 21 25th November 2011 08:57 AM
Copyright ©1999-2019 diyAudio
