Mullard valves
Mullard valves
Old 11th October 2018, 04:44 PM   #11
Alan4411 is offline Alan4411  Wales
Alan4411's Avatar
Llan,
Yours is a Canadian Philips valve.
4X5 is an ECF82/6U8. Little r is from the Ontario Philips plant. Probably made in June 1955 (or 1965?)
See the table I posted in post #5 and confirm it for yourself.
You find a lot of Canadian 6U8 / ECF82s under various brands, but most are marked Made in Canada.
Alan
Old 11th October 2018, 04:51 PM   #12
llan is offline llan  England
Default Mullard codes
Thanks for that info Alan, very informative.
Llan
Old 12th October 2018, 09:15 AM   #13
DF96 is offline DF96  England
A number between the pins probably means not Philips manufacture, so you seem to have one Canadian Philips and one made somewhere else.
Old 13th October 2018, 09:47 AM   #14
v4lve lover is offline v4lve lover  Netherlands
Mullard valves
or they can be old, the old rimlocks had numbers between the pins, or the number of the base making machine stamped into the bottom.
Old 13th October 2018, 04:44 PM   #15
Well I managed to figure out what an imported Mullard EF86 coded BY3 plus D9J4 it was made in Hamburg, but I can not quite make out what KBA for a CV181 is and like wise a KB/Z for a CV1438 any ideas lads
Llan
Old 13th October 2018, 06:37 PM   #16
Alan4411's Avatar
Llan
Ummm, well Philips codes only become unified around 1948 as it says in the introduction. These are older types and most likely pre-date 1948 when there was no rational to the coding.
But, you are quoting the CV (Common Valve) codes and these start during the Second World War. KB is a specification the A or Z are manufacturer codes (usually - not always.) Look here please. CV NUMBERS AND UK MILITARY DATE AND FACTORY CODES – MULLARD MAGIC
and here
CV valves
So the CV181 KBA is a Blackburn (Mullard) valve and the CV1438 is an Hammersmith (Osram).
Not straight forward is it!
Old 14th October 2018, 02:53 PM   #17
Llan
Mullard valvesHide this!Advertise here!
FS : Mullard Valves David Bowie Swap Meet 0 23rd June 2013 06:57 AM
FS(UK) KT-88 and other valves vinodt1347 Swap Meet 0 29th October 2011 08:03 AM
Which valves for MF CD-T paultb10 Tubes / Valves 1 7th October 2007 04:42 PM
*Wanted ~ Mullard M8195 Valves TheMooN Swap Meet 1 16th May 2007 02:18 PM
First amp for a new in valves JORGETronic Tubes / Valves 2 12th June 2006 01:38 AM
