Chinese tube preamps???
Old 7th October 2018, 07:24 PM   #1
catsl1 is offline catsl1
Default Chinese tube preamps???
Anyone have experience with this or similar? XiangSheng 728A Vacuum Tube Pre-Amplifier Preamp Shigeru Wada Japan circuit (Silver) I also have seen some knock-offs of the Cat SL1. Any thoughts on these? Maybe some cap changes would make these sound better. My system is too detailed and bright sounding and I have to run my volume control at 7 O'clock position or it is very load.
Any help would be greatly appreciated.
Thanks very much,
Mike
Old 7th October 2018, 08:50 PM   #2
gigigirl is offline gigigirl
Default If you want to try a valve amp,
If you want to try a valve amp, try a DIY PRT-02A 6N2 Tube preamplifier kit base on AUDIO NOTE M7 preamp R130 | eBay (can also be bought it kit form) Change the capacitors to decent ones, also the valves to Russian 6N2-P (may need valve base converters)
Then you will have a very good but reasonable priced unit that will not break the bank if it's not a cure for the problem.
Cheers
Old 9th October 2018, 01:25 AM   #3
Thanks! Is is possible to buy this pre-built?
Cheers
Chinese tube preamps???Hide this!Advertise here!
Tube amp reboot Re: Chinese 6P6P (6V6) Push-Pull Tube Amplifier Kit ts761100 Tubes / Valves 14 31st March 2016 09:40 PM
Amazon tube amps tube preamps royd55 Tubelab 0 2nd May 2014 04:40 PM
FS: A few tube preamps deicide67 Swap Meet 1 9th July 2012 03:45 PM
Are tube preamps always grounded now? charlesp210 Analog Line Level 3 14th September 2010 02:51 PM
commercial tube preamps bonsai171 Tubes / Valves 12 17th March 2004 06:56 PM
