6L6GC PP amplifier with SS phase inverter
Old 11th October 2018, 07:02 AM   #31
artosalo is offline artosalo  Finland
artosalo's Avatar
Hopefully 100K... since I have a bunch of 100K linear pots...
6L6GC with 300 V at screen requires some -25 V to -30 V grid bias. Have you calculated what the raw minus supply should be with the present schematic and 100 k bias balance pot. I quickly calculated that at least some -200 V is reguired, because of so many voltage dividers.
Old 11th October 2018, 04:19 PM   #32
H713 is offline H713  United States
Now that I'm not running my op-amps off of the bias supply, I will probably just use a spare 120 or 130 volt winding on the PT. So in all likelihood I won't be too far off of the -200 number you mentioned.
6L6GC PP amplifier with SS phase inverterHide this!Advertise here!
6N7's in phase inverter service rsumperl Tubes / Valves 9 24th September 2016 07:38 PM
RCA phase inverter? KTMrida4life Car Audio 5 19th September 2015 09:33 PM
Need help identifying a phase inverter LATUBEGEEK Instruments and Amps 6 27th September 2013 11:59 PM
Phase inverter ThSpeakerDude88 Tubes / Valves 37 29th August 2007 03:15 PM
6C8G phase inverter engels Tubes / Valves 4 4th February 2007 06:01 PM
