DC Heaters for Phono Preamp
Old 12th October 2018, 09:38 PM   #51
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I have only ever used dc heaters once and even then it turned out that the AC heaters weren't the problem.
So since then I just use AC heaters and provided care is taken it works out fine.
I elevate the AC source to about 45VDC.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
DC Heaters for Phono PreampHide this!Advertise here!
Phono Preamp PCB wanted - Transcendental Sound Grounded Grid Phono Preamp nathanjh13 Analogue Source 0 14th June 2012 10:19 AM
Tube preamp build help-heaters Barrington Tubes / Valves 15 20th June 2010 09:59 PM
Vreg or Ireg for Phono heaters fred76 Tubes / Valves 1 10th October 2009 12:13 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
