Hum from tube rectifier?
Old 16th September 2018, 12:28 AM   #11
PRR is online now PRR  United States
PRR's Avatar
Originally Posted by Malcolm Irving View Post
...Once an electron ‘got out’ I think it could pass through the glass (not sure about that)... ???
Umm, no. (not at any sane voltage.)
Old 18th September 2018, 01:21 AM   #12
ncc is offline ncc
Send a message via Yahoo to ncc
Thank you all for your support and opinions. Unfortunately, I do not have an oscilloscope, so I could not make the measurements, however I have no hum when I use other rectifiers (RGN1064, RGN1054, RGN2004, U14) so I can rule out hum due to magnetic coupling from power transformer and chokes.
Originally Posted by Alan4411 View Post
I thought the MU12 was a 'direct rectifier' and the filament is the cathode like the RGN10xx rectifiers. In which case it should not matter which end of the filament is used as the DC feed to the first capacitor.
But if as you say your MU12 is a sort of indirect type, you have to use the end of the filament connected to the cathode to feed the first capacitor. If you don't you will have the 4 volt ac supply superimposed on the DC output.
The UU5 is an equivalent with a cathode on pin 3, check the valve socket, and make sure pin 3 (not pin 4) is connected to the first capacitor.
The other difference is that the MU12 needs 2.5A at 4 volts, slightly more than the RGN10xx ones, is the filament transformer big enough? Failing that perhaps the valve is not so well balanced and you have a little half wave hum?
Alan
Thank Alan for the tip, I already tried to change the connection to the first cap to pin 3 (previously, I used pin 4) but there's no change in the hum
All in all, after some trials without success, I came to the conclusion that the hum is probably somehow due to the defective of the MU12 tube rectifier.
Hum from tube rectifier?Hide this!Advertise here!
Which tube Rectifier is good enough for 5902 tube amp ? calico88 Tubes / Valves 14 30th July 2011 05:15 AM
converting tube rectifier to solid state rectifier. tubo Tubes / Valves 26 24th December 2009 12:12 AM
tube rectifier dung0981 Tubes / Valves 6 25th January 2009 12:19 PM
Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? zxx123 Tubes / Valves 4 21st February 2005 04:02 AM
Tube rectifier for VDIGC tube psu ebijma Chip Amps 2 11th March 2004 04:02 PM
