Clairtone S-401 Tube Amp Restoration
Old 21st September 2018, 05:47 PM   #21
mike567 is offline mike567  United States
Your 60hz hum may not be an issue with the original speakers. an old trick was to drop freq response off below 70hz.. Good bye 60 hz hum!
Old 21st September 2018, 06:21 PM   #22
desolationx is offline desolationx  Canada
That's why I am not going to pursue fixing it. It must be a problem with the design/layout of the amp.
One thing I did notice is the hum changes when adjusting the volume. Starting with the volume at the lowest position, the hum decreases as the volume is increased, then it nulls at a minimum but then increases exponentially as the volume is increased to max. Must be coupled thru capacitance and/or inductance early in the signal chain somewhere.
Clairtone S-401 Tube Amp RestorationHide this!Advertise here!
Clairtone Globes with Alpair 12...Done! Douglas Ingram Full Range 25 30th January 2014 09:26 PM
Telefunken Concerto (tube restoration project) DEMIGLAZE Everything Else 1 15th August 2012 03:58 PM
Fisher Tube Tuner Restoration Walkthrough LinuksGuru Tubes / Valves 7 15th November 2011 02:15 PM
Walkthrough: Pioneer SM-83 Tube Amp Restoration LinuksGuru Tubes / Valves 1 21st March 2009 05:09 AM
Old Tube Radio - Restoration Project Algar_emi Tubes / Valves 21 4th June 2008 11:53 PM
