The context of this idea is a dedicated mono phonograph system using a push pull amplifier. The idea is to combine the phase splitter with the initial phono preamp stage. The idea is illustrated here using pentodes for high gain but one could of course use triodes or some sort of totem pole of triodes to reduce noise.
1) I can't see your pictures either.
2) Balanced TT and balanced preamp discussed here countless times.
3) A single ended RIAA network wired between PI outputs won't work.
Thanks will try some more searching.
I have never seen a turntable with balanced outputs before. Are you suggesting that one could rewire the TT to have a balanced connection to the amp?
Very easy with most TT's. I did mine in 5min. People are scared off because technically it voids the warrantee in most cases.
- Tubes / Valves
- How stupid is this idea (P-P Phono)?
