transform simple low voltage OTL tube amp into lower impedance by paralleling tubes
Old 21st June 2018, 05:27 PM   #21
Koonw is offline Koonw
What is the class A limit of your 25W design? How much power would it make into 64 ohms?
Class A is possible with OTL by applying constant plate voltage supply system such as Class G (Class A + Class C), say a constant supply of 120V so the bias can be as low as -25V, this greatly increased the Class A portion and distortion is much reduced. Most 6c33c OTL can output 50W into 32 ohms but the power is tapered off for higher load due to high swing that hit the limit of power supply usually 140V-170V, if higher voltage is used 60W into 64 ohms is quite possible.
Old 21st June 2018, 07:26 PM   #22
cnpope is offline cnpope  United States
Originally Posted by kodabmx View Post
6P3S and 6P1P both work for years at high power levels in my set up.
I also have a commercial tube receiver that was never turned off and the ECL82 tubes lasted 5 years before I changed them to 6F3P. They were weak but still functional. They were the original tubes from the 70s, so they lasted 25 years before I got the amp in the first place. 30 year tube life
Without further details about the usage the receiver got during the 25 years before you acquired it, that is not particularly informative.
The quiescent current in the tubes in an OTL with two 6C33C output tubes is about 200mA typically, so that would mean the amplifier operates in class A up to about 600mW (with 8 ohm load). OTLs typically operate in class AB, except at very low powers.
What really is the point you are trying to make? You evidently don't like OTL amplifiers, but many of the objections that you are raising, or implying, are rather off-target. They can achieve very low output impedance, excellent low-distortion performance, large and very flat bandwidth, and the output tube life is very good. Declaring rather implausible goals of running tube amplifiers at maximum output power continuously for years on end seems to be a bit pointless.
Old 22nd June 2018, 06:59 AM   #23
tubetvr is offline tubetvr
The existing driver should be able to drive extra pairs, and only need about 100V-p to drive 3 pairs of 6c33c to full output @-50V bias
I don't know what you mean by existing driver? I use a split load and in order to get high enough voltage for 4 tubes fed by 175V, (175V is needed to get 80W from four 6C33C) my choice was to reduce current in the split load thereby increasing swing and to add cathode followers DC coupled to the 6C33C grids. I see that you have 220k as grid leak for the 6C33Cs, that is on the limit, less than 100k is better from my experience. 6C33C start to draw grid current when close to 0V so if you want to drive it to that point you need to provide some drive current.
Most of the Spice models for 6C33C is really bad as they don't include the odd behavior at low currents, (there is a "kink" in the anode curve) and they don't model grid current behavior close to 0V well either
Q-tron Audio OTL amplifiers
https://www.qtron.se/
Old 22nd June 2018, 07:29 AM   #24
As cnpope wrote the quicent current is 200 - 300mA so power at constant current, (if you call that class A) would be up to about 0.5W.
Power in 64 ohm is limited by the anode voltage in my 25W design as it is optimised for giving max power in 8ohm and minimum anode dissipation.
If you would increase anode voltage you could theoretically get more than 100W from one pair, the limitation in this case would be the allowed max anode voltage as it should not be higher than 250V for 6C33C.
Old 22nd June 2018, 08:00 AM   #25
The gain of 4 pairs 6c33c is 1.4, not much more drive is required than 3 pairs, as it needs only 100 V-p drive level, this would give you over 100 watts (45V-p, 31V rms) into 8 ohms, you need only 150V power supply as the sim shows, is there something wrong here in the sim, the kink you mentioned does it matter here?
The existing driver in the amps mentioned in the earlier post such as Tim Mellow can handle that. However if the bottom tubes gain is intentionally reduced (by mean of NFB for instant) , it then required more drive level to get the same output as if gain were un-attenuated.
Old 22nd June 2018, 08:47 AM   #26
Yes, maybe but I get 80W with 2 pairs! I can get 100W but I use equalising resistors in the anodes to even out differences between tubes, this reduce output power. In order to use 4 pairs, (8 tubes) you would need to match them very closely or to use large equalising resistors or it would not work. I think it is better and easier to use fewer tubes with a bit higher anode voltage, (higher anode voltage is needed to cater for the increased output voltage) and modify the driver for more drive voltage, (grid bias is higher due to higher anode voltage).
I have never found a spice model for 6C33C that is good enough for much more than idle conditions, the best I found was from an organisation in France, Exceem, they also included the kink and verified the model all true the anode voltage range but not for higher currents than 1A, (of course there will be large differences between tube samples, these differences are not shown in the model). The kink affects distortion and bias conditions, a simple model gives either wrong bias or wrong current for small currents.
Old 24th June 2018, 04:30 AM   #27
PRR is offline PRR  United States
PRR's Avatar
Originally Posted by neazoi View Post
...parallel more than one PL504 to reduce the output impedance so as to be closer to 8 ohms? ...does each tube need to have its own resistors or just parallel them pin by pin?...
Yes. Here is 60 Ohms. Heck of a headphone amp even for modern low-Z phones. 8 Ohm loading suggests 75 PL504s, will make around 0.9 Watts, while eating 560 Watts of 24V power. Per channel!!
BTW, this type resistance-coupled "power" amplifier *sucks*. A choke-loaded power amp can approach 50% efficiency, push-pull can go toward 78% eff. A resistor-loaded amp's best efficiency is a bit over 8.5% MAX. For ideal devices! Using tubes, 4% plate circuit efficiency is fantastically good; counting heater power also the efficiency is about 0.26%.
Old 24th June 2018, 08:31 PM   #28
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
Well, that is a one person's point of view, and many would disagree with him. He obviously has a bit of an "anti OTL" bee in his bonnet.
Turner certainly seems to have that, though he does bring up valid considerations. Any hollow state OTL will be operating into nearly vertical loadlines as you have the complication of trying to make a Hi-Z device operate into Lo-Z loads. Not having "P-Channel" VTs is also another complication.
I have had great success with a variety of different OTL designs. I have never run into problems caused by the negative feedback. I have built OTLs with a very low output impedance, very low distortion, and quite decent output power. (For example, 25W using just a pair of 6C33C tubes.) I've been running some of my OTL amps for years and had no problems with tube failures.
Not that it can't be done, and Ralph Karsten at Atmasphere has done it as well, though some of his designs seem a bit ridiculous. Who needs something like that unless you need to fill a stadium with sound or are plate modulating a big AM rig? This looks like an exercise in "just because we can".
My preference OTL-wise would be hollow state for the front end driving power MOSFETs on the back end. Power MOSFETs in a circletron should sound just as good and you don't need all that extra current to light 'em up. The A Number One problem with MOSFETs is that "complimentary" N-Channel/P-Channel pairs are a good deal less "complimentary" than NPN/PNP complementaries. The circletron answers that problem as you can use N-Channel MOSFETs only.
An OTL with 2 6C33C in inverted Futterman connection can easily give 25W in 8 ohm with high reliability and long tube life. 25W in 8 ohm means that the tubes need to give a peak current of 2.5A and that the average current through the tubes of 2.5/PI or about 0.8A. This exceed the allowed max average current for the 6C33C which is 0.6A and it will also mean that the max allowed anode dissipation of 60W is exceeded.
However as for any amplifier used for playing music the maximum power is never used contionously, music depending on type have a crest factor, (relation between peak and average power level) of 10 - 20dB. So in reality any amplifier even at playing just before clipping level give out a power that is 10 to 100 times lower than maximum.
For the OTL example above with 25W in 8 ohm and a crest factor of 10dB the amplifier give 2.5W average, (if played up to clipping), the peak current will then be 0.79A and the average current through the tubes 0.79/PI = 0.25A which is well inside the limit. The Anode dissipation with 160V anode voltage will then be 40W which is well below the allowed max.
So thats the story on how an OTL can be built with few tubes, (of the right type) and still have good reliability and long tube life.
These days that could be a dangerous assumption. I've seen music compressed to such an extent as to be almost flat across the board. Playing that approaches "brick on the key" operation, so do be careful.
Transistors have ratings; vacuum tubes have guide lines
Old 2nd July 2018, 09:33 PM   #29
atmasphere is offline atmasphere  United States
atmasphere's Avatar
Almost- we've not built very many of that model. But the MA-3 does define the state of the art in many ways- its the most powerful OTL made, and one of the more powerful triode amps made at over 500 watts.
Speaking from experience, its obvious Turner has more than just a bias- he really doesn't know what he's talking about!
Most of our amps are like the M-60 described in the 'what tubes for a tube amp' thread:
What tubes for a OTL tube amp?
The tubes hold up well, vertical load lines notwithstanding, and distortion without feedback is often less than 0.5%THD with IMD below 0.05% into an 8 ohm load at full power (one must be careful not to short the speaker terminals to ground else the distortion and power readings will be a mile off; this measurement problem is a lot harder to avoid than it might seem at first blush), and that's open loop. Such an amp should not exist according to Turner. He must have never actually played with an OTL, best I can make out.
As you point out, the Circlotron obviates the need for complementary devices.
I think the main reason for going OTL is distortion- or the lack thereof. All amps make distortion, and the distortion they make is interpreted by the ear as tonality. This is the 'richness' of SETs or the 'brightness and harshness' of solid state; either way its distortion.
The ear is keenly sensitive to the higher ordered harmonics (which is also easily demonstrated), even in 'trace' amounts of 0.005% its still audible since the ear uses the higher orders to sense sound pressure.
By building a fully differential OTL, you can avoid the more common tube colorations as you won't get the even orders so much, and avoid the brightness often associated with solid state. The result can be astonishingly neutral if one is moderately careful about the speaker load.
Old 5th July 2018, 04:42 PM   #30
stocktrader200 is offline stocktrader200  Canada
Has anyone hooked a scope up to the output with speakers connected to see the waveforms or measure actual distortion with a proper load. My guess is this type of amp performs like an SE tube amp with lower bass extension.
The other test I want to try is a 50w P-P amp driven at the splitter (Concertina) by a solid state amp thereby testing the outputs and transformer for linearity.
the output tube and transformer may be modelled well by a 1 ohm resistor at 50% power levels or less.
transform simple low voltage OTL tube amp into lower impedance by paralleling tubesHide this!Advertise here!
Using a lower voltage indicator light than supply voltage - Safe/acceptable method? DarkDeepRed Construction Tips 12 9th March 2016 02:06 PM
Simple low voltage tube preamp stage billbo Analog Line Level 3 30th May 2013 04:38 AM
Tube rolling input tubes Simple SE Anchan Tubelab 3 14th January 2011 08:05 PM
Lower rails for lower impedance? 95Honda Solid State 7 19th December 2007 09:59 AM
Simple Low Voltage Tube Preamp? CarlosT Tubes / Valves 11 1st February 2007 11:25 AM
