SE SV-811-10 power supply
Old 21st April 2018, 08:19 AM   #51
psherriffs is offline psherriffs  Philippines
A question to everyone- some time ago I built a pair of push-pull amps based on the SV572-10. About 80 watts. They sounded great, and looked nice, but I could never get more than a few hundred hours from the tubes. I got a response from Svetlana (can't remember who) that said they were having issues with gassy tubes. Did they ever go back into production? Were the problems resolved?
Old 21st April 2018, 03:52 PM   #52
audiowize is offline audiowize  United States
Send a message via AIM to audiowize
No, the SV572-10 was basically junked because they never lasted that long.
As far as the DC supply for the 811s goes, plan to put a very low value resistor between the + output of the rectifier bridge and your filter cap. I use very efficient, high power schottky diodes and about 0.04R of resistance between the output and cap in my amps to drop the voltage to 6V. This isn't the easiest thing to model, so do some bread boarding to see what you need. Having a little resistance in this position will reduce the stress on your heater winding a bit.
Old 21st April 2018, 05:55 PM   #53
w5jag is offline w5jag  United States
Originally Posted by psherriffs View Post
..... got a response from Svetlana (can't remember who) that said they were having issues with gassy tubes. Did they ever go back into production? Were the problems resolved?
The 572 family of Ryazan tubes have the gettering imbedded in the carbon plate. They're made to run with color in the plates, otherwise the gettering doesn't work properly.
I have a triplet of the ceramic base 811A that can still do better than 500 watts at 28 MHz at about twenty years in service. They're getting a little soft, but I've got my money's worth out of them.
Win W5JAG
Old 23rd April 2018, 01:59 AM   #54
Lewis1 is offline Lewis1  United States
Default beyond the power supply
Just a general question:
In the Vacuum Tube Valley schematic (SV811/SV572 SE1), Eric Barbour uses 4 33k resistors in parallel to get to 8.25k.
In the second Glass Audio schematic attached here, he uses 4 12k resistors in parallel/series to get to (I think) 12k.
I'm sure there is a good reason for the multiples, but what is it? Is it just a power handling consideration? But even if that's the point, couldn't I just use a single 5W or 10W of the appropriate value?
Lewis
Old 23rd April 2018, 11:32 AM   #55
jdg123 is offline jdg123  United States
jdg123's Avatar
Some well respected designers have asserted that paralleled resistors sound better... but in this case Iím pretty sure it was a cost saving measure. The design was intended for a budget minded builder. And too, the number is sometimes hard to hit with a single piece.
Old 25th April 2018, 03:18 AM   #56
Well, I'm learning that it is difficult to get the voltages you want if the transformer specs are to far off. My 315-0-315 transformer puts out too much voltage with a bridge (I've learned that some capacitors smell like popcorn when they pop!). And I think it will be too low if I use a full-wave tube rectifier. Back to looking at power transformers for this project.
Old 25th April 2018, 04:35 AM   #57
Do you have the supply loaded while you're testing it? If you power things up without a load, the B+ will be too high. It shouldn't be so high that your caps fail though, that's an indicator to use higher rated caps.
Old 14th March 2019, 10:47 PM   #58
Perfectusaudio is offline Perfectusaudio  Australia
Hi, Does anyone have a schematic with the SV811-10 or SV572-10 yielding 15 watts or so as I don't want to go much above a 650v rail ? I need 15-16 watts for 90dB/1 watt speakers
Old 16th March 2019, 11:02 AM   #59
45 is offline 45  Italy
45's Avatar
IMHO, if you can find the 811-10 at much lower price than 300B then it's worth doing. Otherwise the 572-10 is a better option.
With the 572-10 you can use an existing 211 schematics as a starting point and maybe even definitive....This also means that lowish voltage can be done but is not ideal. You are just shifting the troubles from the output stage to the driver. You can get 16W clean in class A1 without going into positive grid with 1000V/70 mA and 8K transformer. You can use self bias, transformer coupling and possibly even RC coupling (together with self biased 572 only, IMHO) if you want to start with a simple driver and then upgrade it at second time. If your speakers have minimum impedance in the 5-6R range use 10K transformer with 75 mA as a starting figure.
Old 17th March 2019, 10:04 AM   #60
CijTele52 is offline CijTele52  United States
Another option is to bias the tube with much higher current. At 700V 110-120mA, if you can drive grid to positive region, you can get about 25W using 5K opt.
SE SV-811-10 power supplyHide this!Advertise here!
If a DAC asks for a 7v - 9V power supply, should I used a 9v 2000 mA power supply, or ag8908 Digital Line Level 2 26th March 2014 06:24 PM
Making Symmetric Power Supply from Single with 4x ATX power Supply? lupetalo Power Supplies 11 20th November 2012 11:51 AM
Power supply positive-negative-ground from a single power supply mome Power Supplies 8 9th September 2011 05:17 PM
Hagerman Bugle power-supply or for +/-15dc 100ma generic supply. tweakk Swap Meet 3 23rd February 2011 06:46 PM
Copyright ©1999-2019 diyAudio
