multi-tap outptut transformer
Old 19th February 2018, 05:25 PM   #1
juanitox is offline juanitox  France
juanitox's Avatar
Default multi-tap outptut transformer
hi , i have a 7K transformer runnig a 8 ohm driver on the 8 ohm secondary. if i will run the same driver on the 16 ohm tap what will the impedance at the primary 3.5K ? or another value?
French is not a crime.
Old 19th February 2018, 06:02 PM   #2
jazbo8 is offline jazbo8
jazbo8's Avatar
Yes, 3.5k.
Old 19th February 2018, 06:29 PM   #3
juanitox's Avatar
thanks ! it sounds good like this but now i know why
Old 20th February 2018, 09:27 AM   #4
6A3sUMMER is offline 6A3sUMMER  United States
The losses of the primary due to its DCR, and the losses of the secondary due to its DCR will both be doubled when you use the transformer that way.
Suppose the 7k Ohm primary has a 350 Ohm DCR, and the 8 Ohm secondary tap has a 0.4 Ohm DCR. The losses due to DCRs will be 1 dB.
Now suppose the 16 Ohm tap also has a 0.4 Ohm DCR (it would have to have a little more, but just for discussion, say it is still only 0.4 Ohm). If you put the 8 Ohm load on the 16 Ohm tap, the new loss due to the DCRs would be 2 dB.
multi-tap outptut transformerHide this!Advertise here!
Real multi room, multi input-multi output audio system for smart home gryzli133 PC Based 3 26th January 2018 05:15 PM
Wiring a multi filament transformer? DAK808 Tubes / Valves 4 21st January 2017 05:50 PM
R-Core or split bobbin or torroid multi 9V transformer wanted limono Swap Meet 0 6th August 2015 12:10 AM
Isolation Transformer (multi-winding transformers) acceler8 Equipment & Tools 12 3rd June 2013 10:20 AM
Multi-channel, single transformer diarav Chip Amps 5 7th November 2006 02:04 AM
