Eli Duttmann's phono preamp voltages
Old 17th May 2019, 10:31 PM   #21
Wavebourn is offline Wavebourn  United States
Anatoliy Lisovskiy
Wavebourn's Avatar
The worst ever error on the schematic, grounded rectifier before ever smoothing capacitors. Ground loop hum guaranteed, follow
attempts to eliminate it lifting grounds and buying super-duper audiophile grade cables and power conditioners.
Congratulations!
!!!Warning!!!
Single Ended Class-A-Holism is addictive!!!
Old 17th May 2019, 11:40 PM   #22
Eli Duttman is offline Eli Duttman  United States
It works FINE. You are not looking at FWCT setups.
Eli D.
Old 17th May 2019, 11:53 PM   #23
Anatoliy Lisovskiy
Wavebourn's Avatar
That means, the actual wiring does not follow the schematic exactly, and the drawing is deceiving. Or, you had to implement the ground lift, as I mentioned at the beginning.
!!!Warning!!!
Old 18th May 2019, 12:16 AM   #24
Jeff Yourison is offline Jeff Yourison  United States
Hi, Wavebourn,
I grounded the power supply directly at the rectifier. No hum or buzz. Any other point created a hum or buzz. In the attached photo, see the black wire originating from board just under the horizontal orange drop capacitors and going up and over to the chassis lug on the far right.
File Type: jpg F7BDBA87-3A32-4A47-A301-4BE66920CF0D.jpg (701.5 KB, 221 views)
Old 18th May 2019, 12:54 AM   #25
Anatoliy Lisovskiy
Wavebourn's Avatar
Looks like your board has pretty short trace from the rectifier to the filter capacitor, still the best point would be to ground at the negative lug of the filter capacitor.
!!!Warning!!!
Old 18th May 2019, 05:15 PM   #26
gregas is offline gregas  Canada
Default Power supply
What are your thoughts on using a switching power supply. i have a ac-dc converter and a dc to dc booster. I can use these to get the B+ voltage to run the phono preamp. I was going to try this out and see how it works. If it works well I'd keep it if not i can build a tradition power supply. Eli do you have a better resolution image of that schematic for the power supply?
Greg
Old 18th May 2019, 05:52 PM   #27
Gregas,
Here is a pdf file of the power supply. I hope it will help.
Old 18th May 2019, 06:17 PM   #28
Anatoliy Lisovskiy
Wavebourn's Avatar
Originally Posted by Jeff Yourison View Post
Gregas,
You should draw the ground from electrolytic filter capacitors, instead of from the rectifier, to avoid pulses charging them to be applied to the signal. It may not be a problem in your particular design with very short trace between rectifier and the cap, but people following such schematics make the same error again and again.
!!!Warning!!!
Old 18th May 2019, 09:13 PM   #29
leadbelly is online now leadbelly  Canada
leadbelly's Avatar
Sorry Wavebourn, schematics are explicitly NOT meant to convey wiring or layout information. Look it up in your favourite reference book if you don't believe me.
It is better to remain silent at the risk of being thought a fool, than to talk and remove all doubt of it. Maurice Switzer
Old 18th May 2019, 09:24 PM   #30
I'm not a fan of potential noise makers in audio circuitry. However, you can give it a whirl and observe what happens.
Have you given thought to a DC heater supply?
Eli D.
Eli Duttmann's phono preamp voltagesHide this!Advertise here!
Phono Preamp PCB wanted - Transcendental Sound Grounded Grid Phono Preamp nathanjh13 Analogue Source 0 14th June 2012 10:19 AM
Preamp Voltages diaz028 Tubes / Valves 3 8th October 2008 04:00 AM
Strange: Preamp Xformer Overheating but Not Blowing Fuse and Supplying Right Voltages dtm1962 Parts 4 29th January 2008 12:18 AM
ARC SP9 Preamp voltages topfee Tubes / Valves 8 8th January 2008 02:53 PM
voltages for project 88 preamp oldfatbubba Chip Amps 3 15th August 2007 09:31 PM
Copyright ©1999-2019 diyAudio
