Folded/shunt cascode differential question
Old 31st July 2018, 01:53 PM   #51
Sodacose is offline Sodacose  United States
Sodacose's Avatar
Originally Posted by Rod Coleman View Post
So long as the output resistor is well-rated for the power, nothing bad will happen, even if it is left running in this state for hours.
Thanks for this and the adjustment tips, Rod.
Of course the emitter is setting the anode voltage and the collector resistor is dropping voltage, effectively limiting current. It shouldn't matter if the tube is an open circuit. That makes perfect sense.
I let this project get a little dusty while I was distracted by other things. I came back and have to relearn it apparently. I'm also easily confused by PNP
Pics of the board:
Old 8th November 2018, 04:20 PM   #52
Sodacose's Avatar
This amp is still coming along:
Boards are all assembled, just need to set currents, final wiring, and test. The EL34 outputs are in a garter belt bias configuration.
Old 8th November 2018, 11:27 PM   #53
Hearinspace is offline Hearinspace  Canada
Interesting to see your project SodaC. I was just telling Rod of my plans to use his shunt cascode circuit as the basis of an active line level XO and that one of the approaches I was looking at was in Small's subtractive crossover, which just happens to need a balanced amplifier stage.
Looking forward to hearing how your amp circuit works out. Thanks!
Old 9th November 2018, 03:10 PM   #54
Sodacose's Avatar
Me too
I'm planning to test the shunt cascode boards single-ended/unbalanced initially to get close on the trimmer settings and then wire up with the LTP CCS (simple LED and BJT cascode).
It's a bit fiddly with all the trimmers (voltage reference, anode CCS, tail CCS). I'm hoping things are fairly stable once dialed in. Provided this works out, I'm very interested in trying the shunt cascode single-ended for a phono pre as well.
Old 10th November 2018, 12:08 PM   #55
tikiroo is offline tikiroo  New Zealand
I just built and tested a folded cascode differential based on PRR's post #5 in this thread, intended for use as a phase splitter. I needed something with decent gain that could run off the low supply voltage available (only 155V, output stage is hybrid). Triodes had to be from an ECL85 as I'm using the pentode in the output stage.
See attached. Supply is from a simple Maida regulator, voltage source for the PNP bases is a resistor divider bypassed to B+ (helps with PSRR), anode current sources are just resistors. Gain is about 45 (~90 each side, halved due to grounding the second input). No issues with oscillation or instability, can swing >100V peak to peak, and perfect balance. On start-up the outputs sit at ~124V until the tubes warm up, then falls to the normal operating point with some undershoot.
All in all a very useful building block for the right circumstances.
File Type: jpg Folded cascode differential phase splitter.JPG (306.4 KB, 168 views)
Old 15th January 2019, 06:18 PM   #56
Sodacose's Avatar
Finally in the testing stages:
I'm troubleshooting at the moment. Without the tube I can set the voltage reference and output level no problem. With the tube installed, the reference ends up around 50V (target 150V) and the output at 0V (target 75V).
I'm playing with the tail CCS to see if that's an issue. I'm thinking I probably killed the ZTXs though. At one point I accidentally cranked the anode CCSs the wrong way and was alerted by a dropping resistor heating up.
Old 15th January 2019, 06:22 PM   #57
Rod Coleman is offline Rod Coleman  United Kingdom
работник
Rod Coleman's Avatar
Sounds like the tube wants more current (to itself) than the CCS can provide. If you adjust the CCS maximum limit up a notch, does the anode voltage increase?
Old 15th January 2019, 06:33 PM   #58
Sodacose's Avatar
This was also on my mind. I plan to lower the tail CCS current and try again slowly increasing the anode CCS to see if it's the issue.
I don't understand why it's affecting the voltage reference and that's what got me questioning whether I've killed something.
Rough schematic attached.
File Type: pdf Schematic_PP-shunt-cascode-monoblock.pdf (47.7 KB, 28 views)
Old 15th January 2019, 07:31 PM   #59
работник
It's possible something is dead, but if the tube eats the whole CCS output, and is still hungry, the output will fall even if the reference circuit is good. I would say this is the most likely problem.
Don't worry about having a little too much current - if the output resistors are correctly chosen, the power dissipation is limited.
Old 16th January 2019, 01:50 AM   #60
Sodacose's Avatar
Rod, you were exactly correct. I just needed to be a little more patient and methodical.it is now biased up and behaving as I'd expect! Thank you for the encouragement!
Folded/shunt cascode differential questionHide this!Advertise here!
Cascode question re shunt to lower tube geezertron Tubes / Valves 17 24th February 2016 10:15 AM
Differential Shunt Cascode Driver Ejam Tubes / Valves 21 13th September 2015 02:46 PM
Folded Cascode in the Making wrenchone Solid State 11 6th March 2010 02:11 AM
folded cascode the_tool Chip Amps 1 27th June 2006 10:53 PM
Folded cascode question Won Solid State 3 11th January 2002 08:10 PM
Copyright ©1999-2019 diyAudio
