Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Tubes / Valves All about our sweet vacuum tubes :) Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum |
Thread Tools |
#31 |
The Blonder-Tongue Audio Baton replica on the way, I just finished one channel and test it.
I stick to the original schematic but I add a 5 led bar graph, led VU meter and an unusual power supply that works very well. The second channel will be upside down for fit inside a 3U cabinet and when finish will looks as the picture of the front panel. Both channel will be completely independent. Sound is excellent just some minor noise issue but I will work out on it, this is just the first test. All the best to everybody. |
#32 |
Spreading triode love.
That little boost module might be your source of noise. I have found them to be terrible, quite frankly.
I would recommend trying one of these instead if you do determine it's coming from the boost module. DC-AC Converter 12V to 110V 200V 220V 280V 150W Inverter Boost Board Transformer | eBay Awesome project man. Koda
If you can't learn to do something well, learn how to enjoy doing it poorly. |
#33 |
Hi Koda thank you very much for the tips, on the first test was very terrible then I add a resistor and 100uf cap and the bad noise goes away, the remaining noise is very small and I think is because all the potentiometer are not grounded yet, but I want for sure try the inverter boost you suggested, I know you have a big experience on it....thanks again
#34 |
You're welcome. Since you're in the Philippines, you can probably find another seller that offers them for like 1/2 the price. Look around on eBay and Ali.
One nice thing about the one I linked is it's push pull instead of SE, and it's isolated. I use them for negative supplies for bias, too ![]()
#35 |
I already find it https://shopee.ph/SUNYIMA-DC-AC-Conv...930.5163547118 thanks
#36 | |
#37 |
Glad it worked out for you!
#38 |
Koda, is that boost module regulated or ratiometric? I.e. if you feed it higher than 12V will it output a proportionally higher voltage? Thx
#39 |
It's ratiometric. If you run it from a regulated 12V supply it's as good as regulated though.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Are we committing suicide?! (Asbestos in vaccum tube base) | ARIYAHOOR | Tubes / Valves | 41 | 13th June 2012 06:07 PM |
Minature Vaccum Tube Question | Mark A. Gulbrandsen | Tubes / Valves | 12 | 1st June 2005 05:01 AM |
Lm4780 with vaccum tube | almu100 | Chip Amps | 0 | 27th February 2005 02:48 PM |
MXR Equalizer Model 170 schematic needed | rh1530 | Instruments and Amps | 0 | 24th January 2004 02:54 AM |
New To Site? | Need Help? |
