Looking for a Tube Kit Amp for my Living room
Old 21st October 2017, 06:14 PM   #1
HarryY is offline HarryY  United States
HarryY's Avatar
Default Looking for a Tube Kit Amp for my Living room
I'm looking for a tube amplifier kit, mostly because I don't have the facilities to make a nice looking chassis.
I currently have a Elekit TU-8200 in my office/Den but it's only 8 watts so a bit light for use in my living room.
I'm thinking something in the 25-50 watt range should be plenty for my living room.
The Dyanakit ST-70 looks good but I figured I should ask before I buy to see what else is available.
Any suggestions?
Thank you.
Old 21st October 2017, 07:53 PM   #2
rayma is online now rayma  United States
These are pretty nice stainless steel replica Dyna chassis. Chassis
You can make a pair of Dyna Mark IV amps using these chassis and replica
Dyna transformers with your own driver circuit. Transformers
Or a complete replica Dyna amplifier. Amplifier Kits
Old 21st October 2017, 08:04 PM   #3
kevinkr's Avatar
Depending on the speakers you are using 8W per channel might be enough if you are not rocking out.. ( )
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 21st October 2017, 08:20 PM   #4
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Any suggestions?
Thank you.
I feel bad I sold a set of original ST-70 metal for a song at a swap meet.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 21st October 2017, 08:38 PM   #5
drpro is offline drpro  United States
Harry I have been considering the Elekit. Your thoughts?
Tnx
David
Old 21st October 2017, 08:53 PM   #6
HarryY's Avatar
drpro,
I'm pleased with the TU-8200. It sounds good.
Old 21st October 2017, 09:05 PM   #7
Mr_Zenith is offline Mr_Zenith  United States
Mr_Zenith's Avatar
Hi HarryY,
I've been running one of the ST-70 kit clones for about eight years now, and I can recommend it without hesitation. I was easy to build and has done everything I've asked of it - and the tubes are cheap to boot. The ability to switch between ultralinear and triode modes is nice too, when the occasions arise; it's like having two amps in one chassis.
I haven't any direct experience with any of the other ST-70 clones out there but I'd imagine they're capable of similar performance. Parenthetically, I'd originally considered restoring an original ST-70 before buying the kit, and was astonished to discover that the total cost was more than if I'd simply purchased the kit - and I still would've had a 40+ year-old amp with a flaking chassis. But if you could find a donor amp or iron for cheap, that just might be your ticket.
Just my $0.02...
Old 21st October 2017, 10:26 PM   #8
Steve Morley is offline Steve Morley  Canada
Elekit TU-8340VK with Genelex reissue KT77s and Tungsol reissue 12AT7s.
DIY Powerhouse: Elekit’s TU-8340VK Amplifier Is Not Your Grandfather’s Dynaco | Wall of Sound | Audio and Music Reviews
Cheers, Steve
Old 24th October 2017, 02:04 AM   #9
booangler is offline booangler  United States
Looking for a Tube Kit Amp for my Living room Send a message via AIM to booangler
Take a look at Oddwatt
Old 24th October 2017, 02:44 AM   #10
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by Mr_Zenith View Post
I haven't any direct experience with any of the other ST-70 clones out there...
I sent my 2 basket case ST70s to Gregg-the-Geek and got back the prototype DynaMutt, an outstanding amp. Switches between triode & pentode modes.
Classic Valve Design - Dynaco Clone and Original Design Boards
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Looking for a Tube Kit Amp for my Living roomHide this!Advertise here!
The Qualias - centerpieces for living room mushroommunk Multi-Way 17 7th March 2018 07:18 PM
5-way active filtered living room set juulmaessen Multi-Way 41 18th October 2017 08:08 PM
Large living room Speaker suggestions gorfeas Multi-Way 15 9th January 2012 07:23 AM
Mikasa or Saburo in my living room? Wha' DIYa know? Full Range 9 21st April 2009 03:51 PM
Hello from my living room. Which is in Oregon m00n Introductions 5 10th February 2004 02:31 AM
Copyright ©1999-2019 diyAudio
